AC injectors
Old Apr 21, 2017 | 11:44 PM
cj_1776's Avatar
cj_1776
AC injectors
I accidentally made this post in the wrong section of this website (engine building section) and got some answers that didn't make sense. I have heard that AC injectors for a Powerstroke will add 40+ HP to a powerstroke truck engine. I believe these come out of busses and industrial vehicles . Can anyone confirm? Also does anyone know anyboy who has ran these in their truck?
Old Apr 22, 2017 | 08:42 AM
7.3 forever's Avatar
7.3 forever
If I'm correct ac codes are the injectors they put in high torque models of international motors
Old Apr 22, 2017 | 08:59 AM
fordman67's Avatar
fordman67
Welcome to the dark side. First off throw out HP numbers in relation to Injectors(no Cummings here) . Cc of fuel/nozzle is more descriptive. I believe ac inj are 120cc . these originally came with 90cc injectors. Those if in good condition are a good upgrade if used with proper custom tunes to make them work correctly.
Old Apr 22, 2017 | 10:46 AM
7.3 forever
I actually believe there equivalent to stage 1s
Old Apr 22, 2017 | 11:05 AM
friskyjake's Avatar
friskyjake
A/C inj
There 160 cc.s I,ve had new a/c .s in my truck for many years. With D/P,s live tunes & my 17 * hopo I have had it dyno many times & on different dyno,s & the #,s are 347 to 357 hp. 1995 f350 ordered new friskyjake
Old Apr 22, 2017 | 12:23 PM
fordman67's Avatar
fordman67
Oops. My bad. Either way get tunes and efuel system!
Old Apr 22, 2017 | 12:49 PM
z31freakify's Avatar
z31freakify
By adding just injectors on stock running you won't net you squat, what does is tunes, and by tunes I mean custom not of the shelf stuff, live tuning would be better.
Old Apr 22, 2017 | 07:16 PM
7.3 forever
Have a question regarding tuning I have a 96 f250 running 35s d66 with 1.00 exhaust housing and 175s efuel and zf right now I just have jeneric tunes on a ts but I'm waiting to get custom tunes till I decide if I'm swapping back to a auto or staying manual I know I know got to watch my egts with wrong tuning I've actually just been running it stock for most part but I'm curious what kind of horse power I should expect from custom tuning thanks guys sorry to hijach ur thread
Old Apr 23, 2017 | 04:28 PM
cj_1776's Avatar
cj_1776
They are 160cc. I am planning to get a hydra chip for my truck to accommodate.
Old Apr 23, 2017 | 04:29 PM
cj_1776's Avatar
cj_1776
Will that result in torque/speed gains?
Old Apr 23, 2017 | 09:59 PM
Chris56ford's Avatar
Chris56ford
lost
You won't notice a big difference in power but custom tunes will smoke a lot less and be smoother. The canned tunes for the stock 90cc injectors have a long pulse width which will give you lots of power with the 160cc but lots of smoke and high EGTs.
You will notice a huge difference going from stock 90cc to 160cc AC Code injectors with proper tuning. AC Codes with proper tuning and supporting mods should net you 325 to 350hp and 700+ lb ft of torque.
Old Apr 23, 2017 | 11:55 PM
cj_1776's Avatar
cj_1776
What kind of supporting mods should I invest in? I just have basic stuff like a K&N Cold air intake
Old Apr 24, 2017 | 09:50 AM
cj_1776's Avatar
cj_1776
I looked a little deeper into the injectors and they came in the T444E International engines which are essentially the same as 7.3 Powerstrokes, just small differences such as different intercooler set ups.
Old Apr 24, 2017 | 02:12 PM
Jarrett Campbell's Avatar
Jarrett Campbell
Supporting mods are a very, very slippery slope.
If you have a K&N, you might want to look into getting a Napa 6637 type filter. It is a filter with a much smaller filter rating but flows just as well as the K&N. If you live in a dusty area, this is a very necessary change to avoid dusting your turbo wheel.
Also, if you have an auto trans, you might want to look into getting a HD rebuild or at least a very quality torque converter. Manual, you might look into a Single Mass Flywheel (SMF) and clutch package.
Intercoolers are also a great upgrade, especially if you have larger injectors and a smaller turbo.
Other than that, studs and springs aren't really necessary until you are pushing 40lbs of boost. I was only able to get about 32 lbs out of a stock turbo and stage 1s, which is about average from what I have been reading.
Just my two cents... Others might have a different opinion, but that is the beauty of it. You can make whatever you want out of your rig based on need, want, and budget.
Tim Hodgson
65
Nov 30, 2012 01:22 PM
UNTAMND
Apr 15, 2010 10:04 PM
UNTAMND
Jan 15, 2010 10:13 AM
suzuki_vinson
34
Apr 19, 2009 08:21 AM
audimaster
Nov 11, 2007 05:34 PM
