1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Blowing oil out my exhaust
Old 04-21-2017, 11:21 AM
Davidson7.3's Avatar
Davidson7.3
Davidson7.3 is offline
Any ideas 💡 my truck is a 2000 7.3 doesn't smoke on start up but once it gets to temperature it does. I'm not going through any antifreeze, just oil and it's coming out the exhaust. The truck still runs great starts right up every morning without being plugged in. Any opinions?
Old 04-21-2017, 11:57 AM
kcducttaper's Avatar
kcducttaper
kcducttaper is offline
Might be different with diesel than a gasser (though the principle is the same), but the first thing I would look at is either the piston rings or head gasket. Oil is thick when it's cold, so it won't be as prone to squeezing through the tight space of a damaged ring or little hole in the head gasket. Once it warms up, it will flow a bit more freely. Might be worth a compression check and/or poking your nose down the oil fill to check for exhaust gasses.
Old 04-21-2017, 12:35 PM
andym's Avatar
andym
andym is offline
Could be a turbo seal too.
Old 04-21-2017, 01:31 PM
kcducttaper
Good call - I'd brain farted on that one.
Chase-brown
11-12-2018 10:43 AM
SOL4R
EcoBoost (all engine sizes)
01-10-2018 01:28 PM
Jordan84
04-25-2012 12:31 PM
mikecwik
05-05-2010 10:23 AM
paintman
06-10-2003 09:00 AM
Quick Reply: Blowing oil out my exhaust
