Bone stock engine...what's safe to modify?
Old Apr 21, 2017 | 10:53 AM
Chris Hart's Avatar
Chris Hart
Bolts. No arp stud engine. Has 3inch exhuast striaght pipe. Egr delete. Everything else stock including air filter. What will help the engine. Like air filter change to cold air intake type stuff.
What should I buy?
Old Apr 21, 2017 | 10:59 AM
2006powerstroke90's Avatar
2006powerstroke90
Get gauges to monitor parameters, coolant filter, leave intake alone.
Whats the year?
Old Apr 21, 2017 | 11:01 AM
navistarnut's Avatar
navistarnut
Leave the filter housing, it's more than adequate and does the best job.
3.5 inch down pipe, into a 4 inch pipe.
Atlas 40 FICM tune.
If not already done, perhaps 5W40 synthetic diesel rated oil
Others use a tuner to varying degrees.
What year is it?
Old Apr 21, 2017 | 03:19 PM
packagerjr's Avatar
packagerjr
I second the gauges, including a coolant system pressure test. You may have more money to burn than I do but I would want to know if the platform is solid before throwing money at shiny objects. It's possible to be sitting on thousands in repairs but not know it just driving around town.
I would do the blue spring. Easy upgrade.
I may do an Atlas 40 after I get my EGT gauge installed as the truck is mainly used for towing.
​​​​​​​Make sure your CAC boots are in good shape. I picked up a couple psi of boost exchanging my tired MC boots for RiffRaff boots.
Fabbed5.0
Sep 27, 2013 06:44 PM
MarzRickey
Jan 3, 2013 08:31 AM
hfdbuck09
Jul 30, 2010 01:21 PM
JustinSWeber
Dec 9, 2007 02:21 AM
Tuff48
17
Dec 29, 2006 12:19 PM
