TRUCK WON'T STAY RUNNING!
Old 04-20-2017, 09:46 PM
moparpig77's Avatar
moparpig77
moparpig77 is offline
Just bought a 1983 Ford F250, 7.0, manual, dual tank, carbureted, manual fuel pump...
Truck has set lonesome for the last six months, put a new battery in her, filled the gas tanks and replaced the fuel filter.
Truck turns over strong, fires... Then shuts off after 5-10 seconds. Bogs down under throttle.
I double checked the prime on the carb, checked spark ok.
During cranking/firing the ignition coil turned damn near red hot!!!
So, yeah here we are. Any suggestions?
Old 04-25-2017, 01:41 AM
cbakker's Avatar
cbakker
cbakker is offline
Define bogs down under throttle. Has the motor been built?
Old 04-25-2017, 03:52 PM
CountryBumkin's Avatar
CountryBumkin
CountryBumkin is offline
If coil is heating up - i would start there. Are you running the Duraspark ignition module (or some aftermarket setup)? What is the voltage to the coil when running?
"Top Fuel" Bender
12-18-2011 09:40 PM
dirtdude007
01-22-2006 11:51 PM
utpow
10-11-2004 07:16 PM
liktofish2
02-02-2004 06:13 PM
F350SuperCab4x4
Electrical Systems/Wiring
08-30-2003 06:28 PM
Quick Reply: TRUCK WON'T STAY RUNNING!
