Sponsored by: Real Truck
tire size
Old Apr 19, 2017 | 11:24 AM
ryanf250's Avatar
ryanf250
tire size
Hello all, I have a 2005 fx4 extcab 5.4, it has 265 70 r17 tires stock, I want to go 285 70 r17, anyone know how much my speedo will be off, the 5.4 is no power house, will the trans down shift more by throwing the ratio off this much, it doesn't seem like much to me but maybe someone here had experience before I order tires, and I am planning on mounting Kenda Kliever MT's 10ply. thank you!
Old Apr 19, 2017 | 12:56 PM
Ford744's Avatar
Ford744
A 265/70R17 is 265 / 25.4 * .7 * 2 + 17 = 31.606 inches tall.
A 285/70R17 is 285 / 25.4 * .7 * 2 +17 = 32.709 inches tall.
The 285 will be 3.5% taller.
Now, there is a difference between all tires, some brands will run slighter smaller or larger given the same size. If you can compare the tire diameters from the manufacture that will be more accurate. But 3.5% is approximately where you'll be at. At 30mph that's 1mph off, at 60 that's 2mph off. Not a big deal. A taller tire effectively changes your overall gearing. At the same speed you will be running slightly lower engine rpms.
Old Apr 19, 2017 | 01:01 PM
seville009's Avatar
seville009
https://tiresize.com/calculator/
Old Apr 20, 2017 | 10:07 PM
Bigred5348's Avatar
Bigred5348
4wd Low
The trans will turn the 285's with no problem. I had an 03 with the 5.4 ran the 285's for 11 years on that truck with no problem turning the tires over.
Old Apr 21, 2017 | 10:03 AM
ryanf250's Avatar
ryanf250
Thank you!
Gage2502
Sep 29, 2012 04:59 PM
5.4f250sd
Mar 25, 2011 06:13 AM
calexan
2004 - 2008 F150
Aug 5, 2009 07:01 PM
drew1485
Feb 22, 2008 08:33 PM
copeina
May 25, 2002 12:52 PM
