Sponsored by: Real Truck
Electrical disconnects before welding
Old Apr 18, 2017 | 06:46 PM
Heaveyhauler05525's Avatar
Heaveyhauler05525
05 f350 6.0 diesel, I am going to do some rust repair, A will be mig welding of replacement rocker panels. I know I need to disconnect the batteries, Is there anything else I should disconnect: FICM ? Injector control module ?.Any imput would be great Thanks
Old Apr 19, 2017 | 09:25 AM
speakerfritz's Avatar
speakerfritz
I do TIG. MIG, stick, flux welding often on trucks.
run a ground rod into the ground and use a jumper cable to ground the frame close to your weld areas.
disconnect matteries
disconnect (once the batteries are disconnected), the two main connectors to your computer.
TIG would be a better choice for body panels.
Old Apr 26, 2017 | 06:18 PM
Heaveyhauler05525
Disconnects before welding
Thanks for the info, I have a tig welder as well and will use it for this project. Great Idea about the grounding rod.
Thanks
sealer700
Jan 16, 2016 01:05 PM
al3x
16
Sep 11, 2009 09:57 PM
Ray 450
Paint & Bodywork
Aug 14, 2007 08:48 PM
Flaflathead
Dec 19, 2005 08:45 AM
1985ColumbusF150
Garage & Workshop
Nov 28, 2004 06:14 PM
