"Non servicable bolt" failure in HPOP
The other way a pump could fail is if something got inside the oil and damaged the internals (or the internals broke apart) which would be a pretty terrible thing to happen to the motor. I don't think this is very common at all so I wouldn't worry about it.
As far as I know, even the stock injectors can be limited by the stock HPOP if the truck is asked to do moderate or heavy work, and gains have been seen even with normal driving conditions when a better HPOP is put in (like the super duty 17 degree pump or something better.)
Long story short, I wouldn't trust that mechanic shop if they believe that there is no advantage of having a better HPOP in there, especially if they just want to slap on a remanufactured obs HPOP in place of your T500. On top of that, they warrant the pump needs to be replaced because the "non-serviceable plug" is leaking. It's very common to have this plug replaced/upgraded.
If you were down in Phoenix maybe I would have taken my Bronco to you guys to get some work done! I don't know if I could afford anything as involved as swapping the motor out like I'm doing now, but having a reputable set of hands look over my setup sure would help! I just hope the replacement motor I'm working on now doesn't have the fuel in oil issue I had before (and that it's compression is at least acceptable!)
Haha yeah thats a good comparison! Makes sense that the upgraded pumps are better if they allow a higher volume! That way the pressure can stay as consistent as possible when the need for more oil arises!
I just got the HPOP out of the truck ready to perform the fix. As I pulled it the shaft lip seal on the pump was looses and came out. Its in bad shape and should be replaced, cracking and falling apart. I cant seem to find that lip seal anywhere, including dealership. Anyone know where I can get one? There not at riffraff or diesel orings either
Im talking about on the pump itself. With the pump removed and looking at the shaft end (where the gear bolts to) theres a lip seal that seals the pump and the shaft (where the gear bolts to). It doesnt come in any kits I assume because only the people rebuilding the pumps deal with this seal
I just took a look at my t500 (still in the bag it got shipped since I'm not ready to install it yet) and saw the seal you are talking about. It's a 'rear main' seal type looking seal that slides around the pump shaft.
For a quick search, I cannot find a replacement seal to order either. I'm sure someone has to provide them though!
I don't know 100%, but I think that seal holds back LOW pressure oil (probably provided to the pump) because I can't imagine a seal like that holding high pressure oil. On top of that, IF that seal leaks, it should leak in between the pump to HPOP reservoir, which has a gasket, meaning that oil would leak back into the crankcase which doesn't seem too bad (as long as that pump is being supplied with enough oil.)
I don't believe this seal would cause there to be an external oil leak in the valley though unless your HPOP to HPOP reservoir gasket was bad.
If the shaft seal is in bad shape, I would try and look to find a replacement before putting in back on though. I'll keep looking at post if I find something.
Well from some searching, still no luck finding the part but here is a post from another forum about what someone measure for dimensions.
"Ok I need help. I have the swamps hpop parker hydraulic pvp 16 pump. Tues. I was running the truck, shut it off went, in to open the garage door, tried to start it, won't start. So cked out found the pump/gear was slipping. Tore the pump out to run to the machine shop to fix the problem once and for all but as I was taking the pump out, I found that the main shaft seal's inner lip was tore and sticking out between the seal and shaft. Called swamps and they called the company that suppiles the pump (southern hydraulic or something like that). Well they still don't have an answer, I have tried several companies to cross it with no solution yet. it is a viton seal with the following dimensions:
inch----------des.----------metric
.98...........shaft size..........24.91mm
1.77-------bore size--------44.96mm
.430..........depth size..........10.922mm
.485-------max. depth-------12.319
..............(that will fit)
it is a double lip with spring.Guess I going to miss Mondays pull too. This year is not going well, I have missed more pulls this year than the last four years of pulling. I think I might just have to go out drinking tonight. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Thanks for any and all help guys
Dorian"
This seal may be something you'll have to get a hold of Joey or someone else to get a replacement. Maybe someone else will chime in.
Dorian"
#28
Thanks for putting in the time looking at that. Anyone else know?
How about Joeys contact? I emailed him (Joey@terminatorengineering.com) and got kicked back a message saying the email is no longer.
#30
Riffraff forwarded my question to Joey, we'll see if he contacts me. I figure he should be the guy I get in touch with for this problem.
