17 SD Heavy TT Setup help
I'm considering installing a new curt hitch with an 18000 lb rating, 1800 lb tongue weight. I'm also considering simply pulling with the weigh safe hitch and getting a set of airlift air bags to get rid of the sag. I haven't noticed a difference in sage with or without the WDH hitch.
I'm open to thoughts/suggestions on what set ups are going to pull this trailer most effectively and not damage the truck.
If you aren't seeing the sag getting better with the WD bars, then I'd say you aren't set up right. It's impossible to say much from here. Knowing the axle weights would help a lot.
To me, it looks like your WDH is not set up correctly. The spring bars should be parallel (or close to it) to the ground when cinched up. The head assembly should have some means of adjustment so you can achieve this. My thinking is that when you are turning there is not enough chain to accommodate the movement and is actually binding and adding additional stress on the whole hitch assembly.
Do you know the rating of the spring bars?
1) Truck without trailer attached
2) truck with trailer attached but WD bars unhooked
3) Truck, trailer with WD bars hooked up
3b, 3c etc) adjust WD bars and load until you are happy.
the thing I look for with a WDH is how much weight is being added BACK to the trucks steering axle. I've driven combinations with inadequate weight on the steering axle and it's spooky as hell. Since you aren't happy with the sag, you'll obviously be looking at drive axle weights too, but the way to fix both is the same.
Those integrated tongue weight scales are neat, but I wouldn't consider them a replacement for the "full picture" you get from the CAT scale. Best of luck.
I have the higher rated Curt receiver and drawbar as well as air bags, which work very well for pulling my boat, 5er, and two TT's without a WDH. However, my heaviest TT is about 500 pounds lighter than yours. So I'd be a little leery of running that rig without a WDH. My recommendations:
1. Weigh the truck so you know how much weight is on each axle.
2. Hook the trailer up and see how the weight moves between the axles. You want to ensure you don't exceed the rating of the drive axle or lose too much weight on the steer axle.
If you feel the weight shift is too much to safely drive, ditch that WDH for a better, higher rated unit.
If you are seeing only a couple hundred pounds coming off the steer axle, then you can be confident with the upgraded receiver and air bag route.
I think you'll be surprised at how little weight actually gets shifted off the steer axle.
If you decide to go to the scales, please be sure to post your findings!
That being said, I'm not a big fan of how they link their conclusions to the observable facts.
More than once they state their concern over reduced steering and braking ability, though that is only a conclusion based on reduced weight on the steer axle. Even with the WDH the weight on the steer axle was reduced, so the question should be, at what point does steering become an issue? How much weight can be removed from the steer axle and still maintain enough traction to steer effectively?
They manage to shift a large percentage of weight from the tow vehicle (and hitch) to the trailer axles. In this case, I would be concerned that they shifted so much weight behind the hitch that sway could become a very real problem. No mention of that risk by them though.
Bottom line: at no point were the weight limits of any component of the rig exceeded, with or without the WDH. If you are looking for a way to level the tow vehicle, air bags and WDH are equally effective. If you don't use a WDH, you should be concerned about a loss of weight on the steer axle. If you do us a WDH, you should be concerned about putting too much weight over the trailer axles.
In either configuration, it is wise to go through a CAT scale and ensure that no part of your rig is overloaded.
Adding weight back to the steering axle is in my mind the most important reason to use a WDH. Having a level truck is a result of a well distributed load in cases where no air bags are used, but to me, is not the primary concern when towing.
Happy towing everyone!
We need a "like" button!
