Fi Tech fuel injection problems
Old Apr 20, 2017 | 09:17 AM
Joshhighboy's Avatar
Joshhighboy
Originally Posted by COFLHTK
I had a problem with getting the idle correct. I forgot about it until reading this. I cant remember the exact process that they walked me through over the phone, but it had to do with adjusting the butterflies, primary and secondary. I would call them up when you are standing in front of it and can physically work on it. You will need a phillips screwdriver.
COFLHTK is correct, the butterflies must be set to idle correctly. I believe the setting is IAC Steps and you need it between 3-10 if I remember correctly.
Old Apr 20, 2017 | 12:40 PM
AK FORD GUY's Avatar
AK FORD GUY
Originally Posted by hail destroyer
Most respectfully...WHY?!?!?
The beauty of these trucks is ease of maintenance and dependability: No sensors, solenoids, computers and miles of complicated wiring to break on you.....
There is a reason these 73-79 trucks are still on the road with a gazillion miles on them nearly 50 years later: They were BUILT RIGHT THE FIRST TIME.
Not to be a dick, but if carburetor tech is too difficult for you and maintaining a truck with very basic hand tools isn't your thing, maybe consider an 1986 and up F series with EFI.
Different strokes for different folks... no offense taken.
I won't go into my reasons, because truthfully it doesn't matter what anyone else thinks on that matter.
Happy wrenching.
Old Apr 20, 2017 | 09:51 PM
1965kale's Avatar
1965kale
its cold here, then warm the next week
I love my carburetor, and have absolutely zero problems with it at all, it works exactly the way it is supposed too. but you just cant adjust them to start the same at -45 degrees than they do at 90 degrees. Just how cold does it get where you live? my carburetor is in good tune on all circuits right now, but theres just some things they cant do. It being my actual daily driver and only vehicle, I put around 30k on a year, so the convenience of EFI would be nice
Old Apr 21, 2017 | 12:14 AM
hail destroyer's Avatar
hail destroyer
Eh, we get -20 on occasion and as high as 115 here in PA. I tune for it. I like EFI on extreme trail rigs, but that's about it. Have spent too many hours replacing sensor this and circuit that and chasing BS with a scan tool and a multimeter throughout my lifetime on EFI vehicles to be impressed by it.
Good luck and thanks for not being offended
Old Apr 21, 2017 | 09:05 AM
1965kale's Avatar
1965kale
Alright, yea and theres a very real chance I end up saying the hell with it and throwing a carb back on there if it does turn into a Engine Control Mismanagement box haha, but I do want to play with it, part of it is that my truck is in really great mechanical shape, but the paint was a cheep macco paint job 5 years ago and looks a little rough. where I work right now, I'm surrounded by a bunch of spoiled rodeo kids my age, (19-25 years old) and all of them have had their mommy & daddy buy them a 2017 dodge or ford or whatever so they make fun of my rig, just a bunch of spoiled brats. so it would just be cool just too mess with them and get it to where it cold starts on cold days like a new vehicle haha.
Old May 18, 2017 | 01:45 PM
captainwoot's Avatar
captainwoot
I installed my fitech this past weekend, stock 351m , weiand intake, command center non timing control. First impressions after correctly setting the iac steps on a warm idle (3-10) , it seems to work fairly well. only about 100km so far . I will update as it goes. Another member 79rangerxlt has done one on his and was having issues, but have not seen any updates.
Old May 18, 2017 | 09:51 PM
PapaBearYuma's Avatar
PapaBearYuma
Here in Yuma county, the coldest it ever gets is about 28 degrees, and that's about sunrise, and only for a couple days every year. But it does get warm-about 120 in the summer. The elevation is about 200'
I've never had any trouble with cold starts or altitude, but then again, I've never had them in real cold nor over about 5000'
My first 79, 30+ years ago, wouldn't run over 5000'. It was probably jetted too rich, but I was young and dumb, and never did figure it out
With the trucks giving me about 8 mpg, I'd like to see an improvement, but...my EFI Taurus had an intermittent problem that left me sitting on the side of the road entirely too many times. Never could figure it out. So I'm staying with carbs!
Old Jun 6, 2017 | 10:26 AM
elkarcher1716's Avatar
elkarcher1716
My Fitech is almost completely installed. I have a few wires to hook up and the return line to plumb into the filler neck. Pretty easy so far. just hope I don't have to install a pusher pump just to get fuel out of the tank. I will let you know how it goes sometime this week. Every time I go to work on the truck something comes up. getting annoying but that's the way crap goes.
Old Jun 10, 2017 | 02:34 AM
elkarcher1716
So I got the fitech installed tonight and the truck won't start. She cranks and spits and sputter but nothing. I did the initial set up and no go. I have fuel, spark, and checked the timing Atleast 50 times but won't fire. Don't know if there is more tuning to the fitech or not. Anyone have this problem or just me? Thanks
Old Jun 10, 2017 | 03:02 AM
redcreekauto's Avatar
redcreekauto
We've installed several here at our shop, They do require some initial tuning and its a new learning curve compared to anything with a carburetor. Go over each single step one by one. Its easy to miss something. Sounds like you still have a timing issue. Go back over each connection as well. Their have been some instances with bad connectors supplied from fitech.
Old Jun 10, 2017 | 11:21 AM
AK FORD GUY
I know that I had to open up the IAC setting all the way and add extra fuel to get my 360 to fire up. With the IAC opened up, it makes a weird whistling noise for a few minutes, but it's just the air moving through the IAC.
Also, make sure your battery is charged well, the FiTech unit is sensitive to voltage drop.
Old Jun 10, 2017 | 12:18 PM
elkarcher1716
Got it running. Had the firing order messed up but it's running now
Old Jun 10, 2017 | 12:49 PM
  #28
AK FORD GUY
Glad it was something simple.
Old Jun 10, 2017 | 08:50 PM
  #29
PapaBearYuma
Congratulations on getting it going. Looking forward to hearing how it performs for you.
Old Jun 11, 2017 | 09:21 PM
  #30
maddogjohnson's Avatar
maddogjohnson
Nice to hear that you have it running. I'll be installing a FITech on my 390 in the near future so I'm interested in seeing and hearing about your experience.
