351M / 400 quick question
Old 04-16-2017, 07:34 AM
Number4's Avatar
Number4
Number4 is offline
Trying to identify my engine (79 F250) I believe I've narrowed it down to either the 351m or the 400. I say this, because the T Stat housing is on top the intake with vertical bolts.
That said, asumming it to be either engine, are the belts, hoses and ignition parts all the same?
It sounds mean, but this thing is not a race car, that's for sure.
Old 04-16-2017, 08:37 AM
J ballan's Avatar
J ballan
J ballan is offline
Yes externally they are the same.
Old 04-16-2017, 08:56 AM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Received 3,365 Likes on 2,503 Posts
https://www.ford-trucks.com/forums/1...ml#post1485519
351C/M/400 335 series: 8 bolts in rectangular valve covers. Timing chain housing is part of block. Thermostat housing on block. Exhaust bolt holes diagonal.
351M/400 335 series: intake is 12.7" wide the 351C is narrow. The 351M and 400 are identical externally, only internal parts examination can tell them apart. Or measure the stroke.
351W/302/5.0L 6 bolts on trapezoidal valve covers. Thermostat housing on intake. Exhaust bolt holes horizontal.
429/460 385 series: 7 bolts in rectangular valve cover
352/360/390/427/428 FE series: Intake goes under valve covers.
Old 04-16-2017, 09:41 AM
Number4's Avatar
Number4
Number4 is offline
Thanks for he info guys. I'll look a little more. Original sale dox in glove box says it came with a 460.
Old 04-16-2017, 10:14 AM
Number4's Avatar
Number4
Number4 is offline
7 bolts on drivers valve cover.
Old 04-16-2017, 10:21 AM
PapaBearYuma's Avatar
PapaBearYuma
PapaBearYuma is offline
Doesn't seem common, but occasionally a dealer would do an engine swap for a customer. What does your VIN say? J is 460, S is 400 and H is 351
If the engine has been swapped, the VIN remains the same, so the VIN is not the final word-just a starting point
Old 04-16-2017, 10:28 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
351M/400 share the same block casting number because the blocks are the same.
351C/351M/400: There is no timing cover per se, just a flat engine cover plate. The fuel pump bolts to the left side of the engine block in a 6 & 12 o'clock pattern.
4th digit of the VIN is the engine code: H = 351M / S = 400. But this only holds true if the engine is the original.
To determine the engine size, measure the stroke. 351M = 3.50" / 400 = 4.00."
Old 04-16-2017, 12:00 PM
Number4's Avatar
Number4
Number4 is offline
Yeah, I'd read about removing the #1 plug and measuring tdc, piston travel, something of the sorts.
4th character is a J on vin, which matches the owners info. But the 469 has the water outlet on the front of the block?
Not trying to make another identification thread. I'll have to go back and read the previous ones. I thought the 460 had 7 bolt valve covers though, but the water outlet was bolted horizontal.
Old 04-16-2017, 12:08 PM
NumberDummy
J = 460 4V
429/460 = 7 valve cover bolts per side, fuel pump bolts to the timing cover.
351M/400 = 8 valve cover bolts per side.
Old 04-16-2017, 12:11 PM
Idaho Highboy's Avatar
Idaho Highboy
Idaho Highboy is offline
I've performed the stroke test and believe it's the easiest way to tell a 351 from a 400. While it takes two people (or a starter solenoid switch trigger) and a small dowel, it's as simple as:
- removing a spark plug and the coil wire
- "bumping" the engine until the removed-plug cylinder piston is top dead center
- marking your dowel
- bumping the engine until the removed-plug cylinder piston bottoms out, then
- mark the dowel and measure the difference / distance of your stroke.
Just make sure that your dowel is plenty long so you don't drop it into the cylinder
Also, a 460 looks completely different. The valve covers almost have a straight-vertical look to them. Hope this helps...
Old 04-16-2017, 12:16 PM
PapaBearYuma
The 360/390 has the water neck on the front of the block
On the 460, the thermostat housing bolts to the intake manifold
also, the dipstick for 2wd 460 is in the timing cover, and is annoyingly close to the heater hoses
congratulations, my friend-you have a 460!
Old 04-16-2017, 12:25 PM
redcreekauto's Avatar
redcreekauto
redcreekauto is offline
Photos are of a 460. Thermostat housing is on the intake manifold.
Old 04-16-2017, 01:01 PM
Number4's Avatar
Number4
Number4 is offline
Well, the 351M and 400's didn't seem to have much horse power, hadn't even looked at that of the 460. Not sure which powerplant is the most desirable.
This is just a fun truck, no daily driver. So gas mileage doesn't mean anything.
Thanks for all your help guys!
enos82
11-01-2004 08:40 PM
Racetruckin
10-04-2004 02:33 AM
paragod
17
10-01-2004 02:33 PM
paragod
Engine Swaps
09-17-2004 06:29 PM
Blueoval_racing
07-17-2004 08:30 AM
Quick Reply: 351M / 400 quick question
