6-month reviews?
Took delivery October 4, 2016. Now has about 7700 miles. F-350 Crew Dually 4x4 6.7L Lariat Ultimate.
I like this truck still. It pulls strongly, and shifts very smoothly. While I commented on how heavy the steering was coming from a 2016, I really like the heavy feeling at this point. I prefer it to the lighter steering of the previous generation. The leather seats are not getting wrinkle-lines in them like the previous generation did...but some wear is becoming evident along the side edge where you tend to slide in and out of the truck. Nothing serious so far. Seats seem to have settled and become slightly more comfortable, although still not as good (in my opinion) as the previous-gen seats. Ride quality is nice except on potholed and frost-heaved roads. It has a nice heavy feeling. Recently had some seat time in a new Hyundai Sonata rental, followed by a trip home from the airport in our company-owned Subaru Outback. The Super Duty has a very nice heavy, quiet ride compared to those vehicles. The 4x4 system performed very well this past winter. I'm more impressed with the limited-slip rear differential than I thought I'd be. The LED headlights and taillights continue to work fantastically well and look great. BUT...driving home in a hard snowstorm resulted in the high beams and fog lamps becoming completely covered with snow and ice, as well as the C-Clamp day running lights. The normal low beams remained uncovered. I'm guessing Ford created some type of method to heat the lens area of the low-beam headlamps only (minimum requirement)...probably by ducting hot air from the LED heat sink to the front of the light). The taillamps seem unaffected by snow. Maybe because they are high enough off the ground.
The pano-moonroof remains trouble free and awesome. No leaks, despite being covered with more than a foot of snow several times, plus heavy rains and multiple carwashes (not automatic car washes though).
The nav system works great for me. Traffic has always worked. The new instrument cluster with the large gauges and center display is beautiful.
Disappointments: sure, the audio system sucks once you turn it up past 15 on bass-heavy tracks. Some rattles have formed in the truck. The fuel economy seems worse than it should be.
Overall, a tremendous truck.
Overall soundness: No issues with any developing squeaks, rattles, or noises as the miles add up. I travel some for work and have the pleasure or displeasure of renting and driving all kinds of vehicles. In nearly all cases, I can't wait to get back to my super duty for the better ride. The truck steering and handling remain firm and noise-free.
Overall ride quality: From day 1, the truck has had a solid, firm ride, but does ride like an HD truck in some regards. I installed Fox 2.0 all around at about 15k miles. Made a substantial difference on the minor bumps and potholes but no difference to me when hauling or towing.
Report on special options: E-locker is EXCELLENT in the mud (PA oil fields where I hunt). The "three-wheel drive" just provides so much traction. I have stuck past trucks there regularly, but not my 2017. Granted I didn't try hard to stick it, but the affect of the e-locker was impressive. My SD just crawled through every hole and rut. Adaptive steering is also excellent for low speed maneuvering on trails, parking, etc. I do not plow, but I bet the plow guys love it. 360 degree camera package is also AWESOME. Would enjoy a higher res system but for maneuvering and parking it is a huge help.
Opinion on amenities: Cab room is excellent. I have the moonroof and no issues with headroom (I'm 6'2"). My moonroof leaks ever so slightly in auto car wash when the seam is directly under high pressure. The moonroof is so nice and I highly recommend. I wish I would have gone carpet delete. I have cloth seats and they are holding up very well. I actually spilled half a bottle of Cabernet on the driver's seat (no I was not driving) and it cleaned up lickety-split with oxy-clean. My seats are caribou and I thought I was in real trouble but my wife came though. I have the Ford factory bedliner and it is holding out very well. It was slick at first but that went away in the first month or so. No sliding now. Sync 3 for me is great. I use Apple Maps with it and it works great. I have to do a soft reset a couple times per month but other than that it's a good system. I installed AMP powersteps. Changed our world. Wife is 4' 10" and actually enjoys getting into my truck for once!
Truck drive train performance: I do not tow heavy loads but do haul fairly heavy and have no issues. Engine power is more than needed. Mileage when empty is 15.5 to 16.5. When hauling a ton or ton and a quarter I get 15 to 15.5. In the last few thousand miles, I have noticed heavy shifting (up or down) at very low speeds (below 20 mph) but smooth as can be otherwise.
Gripes: I seem to remember something about the fuel tank reserve...
Love the truck nice to drive, quiet inside, comfortable seats (for me) but......
- Radio unit replaced
- Leak in GPS antenna
- Rear door locks on both doors malfunctioned repaired twice
- Front drivers door would not latch twice repaired
- Tranny cooler recall
- Loud bang in rear end, could not replicate
- Fuel tank recall
- Loose drivers seat bottom, new parts installed fixed
- Leaking transmission from the rear seal, sprayed oil all over undercarriage onto rear diff
- Truck sits lower on rear drivers side by 1 1/2"
- Tailgate opens on its own while driving
And they keep coming, scared to drive it anymore. I am sure it is new model issues but I wish Ford would have done better testing so the testing is not done on the backs of the consumer.
I would still buy one of these trucks given the problems I have had. It is a beauty.
- I don't have any complaints about the seats, but I'm also fortunate not to have any back problems, so far at least...
- No leaks anywhere.
- I'm much happier with this transmission than I was with the 2012. Much smoother, the 2012 had split personalities, and the nice one didn't come around much. Actually the reason I sold it.
- 6.7 doesn't seem quite as quick as the 12, power takes longer to come in. I'm sure that's down to the torque management.
- I like the larger fuel tank
- LED's are just as bright as the HID's in the F-150, but I don't get flashed anymore on low beams like I did in the F-150
- Love the adaptive steering, I just wish it was a touch lighter and had better return to center performance.
- Very happy with ride quality, but still waiting on Bilstein 5100's to come out.
- Very quiet, almost too quiet
- 360 camera is nice, but not as useful as I thought it'd be.
- Like the adaptive cruise more than I thought I would.
- I love the smart fob system for unlocking/locking the doors, just grab the handle. But while the push to start button works fine, and I like not having to fumble for the keys, it's somehow less satisfying than a good ol' key. This is probably just a personality quirk of mine.
- My media door works without a hitch.
- No real major improvements in towing performance from the 12. The exhaust brake is nice to have... but it's pretty flat around here.
- Love the electric release tailgate, mainly so I don't have to lock/unlock it all the time
- Fuel mileage is down compared to the 12'... but on par with the 3.5 eco
- I've given up on the auto wipers and high beams, they just haven't quite got those worked out yet.
- Stereo sound quality is a massive disappointment to me.
- I miss the speed dial menu from Sync 2
- I really miss the gallons used on the trip display.
- I miss auto 4x4, only ever had it in the one truck, but it was nice.
- There is this weird leftover speck of metal on the passenger door under the lip of the weatherstripping that prevents it from laying flat.
That's all I got for now, overall very happy with the truck. Happier when I get around to addressing the stereo.
The cabin was very easy to get use to and comfortable and extremely quiet. Love and use the Man step and cargo lights often. The 48 gallon fuel tank speaks for it self. The 6.7 and Trans work very well together, and never seem to struggle. Towed 14,000LB dump trailer with very little effort. Auto exhaust brake and tow/haul mode worked like a dream in the Oregon Mountains. This Truck was built to tow and I smile every time I tow.
This morning I pulled 5yrd's (15,00lbs) of mason sand up 5% grade and around a jobsite with no problem at all. Meant to take a picture of the load but forgot,not sure of the tongue weight but it was heavy!
All the guys on the jobsite was in awe that it jerked 15k around as easy as it did.
Melansk post a pic up of your truck as I don't think I've seen one...
