HD payload clarification
Old Apr 10, 2017 | 06:16 AM
muj0's Avatar
muj0
I'm looking at a 2015 Super Crew 4x4 5.0 f150 and the information I'm gathering states it does not have the HD payload package. Even states its the standard base payload of 7050. However, I'm looking at the summary after checking the VIN and it states it has HD front and rear shocks and the 9.75 axle. Can anyone verify this does have the HD payload or not? Here's the list:
Medium Earth Gray Interior
With Front Fascia - Level 2
Less Bed Divider
Decal - XTR 4X4
My Key
With Conventional Tailgate
Less Tailgate Applique
Less Second Unit Body Covers
With 6.5' Styleside Box
Less Pickup Box Extender
Spray In Load Box Bedliner
Less Bed Ramps
With Base Payload Package
157"/3989MM Wheelbase
XLT/Family Carrier
Chrome Appearance Package 2
Dearborn Plant Build
Less Special Equipment Package
Less Exterior Dress Up Package
7050 LB. GVW
F150 Sales Badge
Less Special Value Packages
Less Ambient Temp/Speed Pack
Feature Content Group 2
Flexfuel Sales Badge
English/French NAS Language Label
English NAS Owner Handbook
Less Water Wading Equipment
Less Tailgate Badges-2nd Level
Equipment Package 6
With Power Front Windows
With Electric Rear Windows
With Privacy Glass
With Fixed Rear Window
With Heated Rear Window
With Medium Length Overhead Console
Less Floor Mounted Console
Less Floor Mat Kit
Adjustable Accl/Brake Foot Pedals
Interior Trim Accent Pack D
Front Floor Carpet Mats
Rear Floor Carpet Mats
With Carpet Floor Covering
Non Illuminated Sunvisor - Drivers
Non Illuminated Sunvisor-Passenger
Running Boards - Tubular Chrome
With Chrome Grille No.3
Less Exterior Wheel Lip Moulding
With Black Belt Moulding
Less Side Auxiliary Step
Electric Operated Rear View Mirror
Dual Power Htd Signal Mirrors
With Black Exterior Mirror
With Driver Seat Back Map Pocket
Passenger Seat Back Map Pocket
Front Seat Armrest/Stowage
With Rear Under Seat Stowage Bin
With Front 4 Way Headrest
Less Rear Seat Centre Armrest
With Drivers Power Lumbar Support
With Passengers Man Lumbar Support
Less Multi - Contour Seats
Less Temp Control Driver Seat
Less Temp Control Passengers Seat
Less Rear Heated Seat
2 Row-H/Ser Flip Up W/Elon Cushion
With Driver 8 Way Pwr.Seat Adjuster
With Pass 2 Way Manual Seat Adjust
With Heavy Duty Trailer Towing
With Chrome Front Tow Hooks
Trailer Tow Lighting Module
Cleat Tie-Down Kit B
Less Fuel Economy Pack
With Chrome Exterior Door Handle
Double Cab (3/4 Door)
With Moulded Gearshift ****
Less Remote Controlled Tailgate Rel
Frequency - 315MHZ
Power Locks W/Auto Lock - Relock
Door Entry R/Cont Unit - Flip Key
Keyless Entry-Illum Pad & Fob
With Variable Intermittent Windscreen Wiper
Less Sun Roof
Less Tu-Tone Accent Colour
Less Body Tu-Tone Paint
Front Bumper - Steel Chromed
Rear Bumper - Steel Chromed
With Front Licence Plate Bracket
Side Air Bag - 1st & 2nd row
With Standard Rear Seat Belts
With 18" Steel Spare Wheel
Tyre Pressure Sensors - 315 MHZ
H/D Dual Front Shock Absorbers
Heavy Duty Rear Shock Absorbers
18 X 7.5" Chrome Wheel
LT275/65R 18C A-T OWL
Spare Tyre - LT275/65R18 A/T OWL
Centre Hub - Version C
With Bright Wheel Lug Nuts
Less Assist Packages
Immersion Heater-110V
Standard Electric Starter Motor
Less Remote Starter
With 49 State/Non Green State Req
Emission Compliance - USA
3.73
Less Elect Locking Differential
With 9.75" Axle
MOD 5.0L-4V DOHC SEFI NA
Single Exhaust
With Chrome Exhaust Pipe Extension
With Mechanical Parking Brake
With 4 Wheel Disc-Brake
Less Brake Control Valve
Less Hill Descent Control
Normal Fuel Fill
Column Shift
Select Shift Tech (SST) W/Thm Swtc
Electric Trans Case With IWE'S
Less Skid Plates
Extended Range Single Fuel Tank
FFV-(Ethanol) Fuel
Steering Col-Man Tilt/Tele-Col Shf
With Locking Steering Column
Leather Steering Wheel
Less Heated Steering Wheel
With Speed Control
With KMH/MPH Speedometer
Dual Note Electric Horn - Level 2
Outside Temp Thermometer
With Compass Display
MFD High TFT Screen
Less Navigation System
Customer Info Display-Package 2
Less Revers Gear Alarm
Less Speed Audible Warning Device
Less Blind Spot Information System
Less Lane Keeping Aid
Human Machine Interface 2
With Perimeter Anti-Theft
Less Rear Parking Aid
Less Automated Parking System
Less Power Convertor
With Satellite Radio Reception
With NAAO Radio Frequency
Mid Audio + CD + Sdars
Less ICE Noise Reduction
With 7 Speakers
Less Radio Subwoofer
With Media Gateway Module
Less Garage Door Opener
Rear View Camera-Fixed
Less Specialty Packages
With Level 1 Headlamps
With Daytime Running Lamps
With Front Fog Lamps
Less Spot Light
Less Right Hand Spot Light
Less Lighting Packages
Less Interior Light Group
Tail lamps - Level 1
High Mounted Stp Lmp W/Cargo Light
Less Trailer Hook Up Light
With Auto Headlamp Plus Wiper
Tuxedo Black Metallic
Generic Country Group 2
150 Series
FL34-5310-TA* L/F Coil Spring
FL34-5310-TA* R/F Coil Spring
FL34-5560-C* L/R Leaf Springs
FL34-5560-C* R/R Leaf Springs
6 Speed Automatic Trans (6R80)
F-150
(-) GVMT Service Administration
(-)"USA"
(-) "Wallis & Futuna"
(-)"GU"
(-)"BRN"
(-)"BZ"
(-)"ATG"
(-)"NCL"
(-)"AW"
Old Apr 10, 2017 | 07:32 AM
xr7gt390's Avatar
xr7gt390
The previous generation F150's had 7 Lug Wheels on the HD package. I'm not sure about the current generation but would guess the same is true.
Old Apr 10, 2017 | 08:13 AM
RainDesert's Avatar
RainDesert
Get the Vin and lets pull the window sticker. I don't think 2015's were actually able be ordered with the HD package although the option was in the order book.
Old Apr 10, 2017 | 08:19 AM
johndeerefarmer's Avatar
johndeerefarmer
There are no 7 lug wheels on the HDPP for the '15+ trucks.
To the OP, find out what the payload is on that truck. If its 2k-3k lbs then should be the HDPP
Old Apr 10, 2017 | 08:20 AM
muj0's Avatar
muj0
Here's the VIN:
1FTFW1EF9FFA43396
Thanks!
The truck even has the 18" wheels required for the HD payload package. I'm waiting on the dealer to send me a pic of the door tag.
Old Apr 10, 2017 | 08:26 AM
RainDesert's Avatar
RainDesert
Here's the link to the window sticker:
http://www.windowsticker.forddirect....FW1EF9FFA43396
I don't see where there is a HD package option but it is a Canada Sticker.
Old Apr 10, 2017 | 08:32 AM
muj0's Avatar
muj0
Thank you. Are some things different for those sold in Canada? Or should I be wary buying one from a dealer who got it from Canada?
This is the first time I've been looking for something so new. I'm a little nervous and want to make the right decision. I'd like to get 10-15 years out of the truck. Pulling our 5500 hybrid TT 5-10 times a summer occasionally going out west. Also will haul firewood a few times a year
Old Apr 10, 2017 | 08:45 AM
RainDesert's Avatar
RainDesert
I have no experience on the Canada truck stuff. Maybe that 7050# GVWR package is a HD upgrade?
Old Apr 10, 2017 | 09:13 AM
xr7gt390's Avatar
xr7gt390
I did an internet search on FL34-5560-C. It came up in a couple forums as the rear spring for a 2016 F150 with the Heavy Duty Package. Since it's on the internet it must be true :0
I'm not sure what you are hauling. A F150 with out the HD package can handle a lot of weight. It will handle a load of firewood with ease.
Old Apr 10, 2017 | 09:18 AM
muj0's Avatar
muj0
My main concern is payload. Me, the wife, and 4 boys (they're young now, but will grow). They'll only ride with me when we go camping pulling our HtT. Fully loaded its 5500 lbs, but has a fairly high dry tongue weight of 650. That will go up a bit fully loaded. We aren't large people , right now we weigh 500 all together. But we would like to take our bikes and firewood as well (why the higher payload is wanted). We do not plan on upgrading a camper at all. We searched for over s year for the perfect HTT for us. I'm towing with a 2000 V10 excursion right now, but I can't rely on it when we take a trip out west next year.
Old Apr 10, 2017 | 10:13 AM
KMP44's Avatar
KMP44
I wouldn't worry about a Canadian vehicle - sometimes available option groups are different, but the F-150's all go down the same assembly line. Dealers around here have more used Canadian trucks than trucks originally sold in the U.S. Just a function of the exchange rate.
As for HD payload, I think there was a frame shortage among other delays, so no 2015's were built with the HD package, although there were internet forum rumors that there was one sold in Canada - maybe you found it!
Wish these were more common. We're in the same boat - our loaded hybrid has a tongue weight of about 850. Then put wood, bikes, kayaks, & people in the truck and we were out of payload. Thought about ordering an HD payload F-150, and also looked at several used 15's and 16's - 6.5' bed, EB's (from Canada). Killer deals, but got sucked in to going for Super Duty to end the payload worries once and for all.
Old Apr 10, 2017 | 10:21 AM
muj0's Avatar
muj0
I was originally going for a super duty. But eventually when my daily driver bites the dust then my truck would become my daily. I'd rather not drive a super duty daily. 🙄
I finally got the dealer to send me a pic of the payload sticker. It's 1760 lbs. I think if my math is right, it will be fine. When the kids are older we will have to out the bikes in the camper or something. It won't be an issue on long trips out west, we won't take our bikes or firewood then. But we do a lot of state park camping within an hour or two driving distance. Some of it pretty hilly (hocking hills state park in Ohio for example)
Old Apr 10, 2017 | 10:45 AM
xr7gt390's Avatar
xr7gt390
That tongue weight seems high compared to the trailer weight however it is within the limits of the F150. You are right about where Ford recommends a WDH. If loading & weight become an issue you may want to look into setting one up.
Hilly & mountains you'll like the 373 gears & you may even like a EcoBoost better than a V8.
It's really hard to stay within the payload capacity of a F150 when you start towing heavier weights.
Did you look at any F150's with the Max Towing package and the trailer tow mirrors? You might like the big mirrors for towing.
Old Apr 10, 2017 | 10:48 AM
muj0's Avatar
muj0
I have looked at them. I think the one I'm referencing does have the max tow. It has the trailer brake controller anyway. And it is 3.73.
If I go to a 3.31 gear will that really suck compare to the 3.73?
Old Apr 10, 2017 | 11:06 AM
xr7gt390's Avatar
xr7gt390
There are a few people on this site that tow with the 331s and are happy. I don't have any personal experience with the 331 other than a test drive. My 2012 F150 had the 373 & the 3.5L EB, that was an amazing towing setup. My current F150 has the 355 & 2.7L EB. I only have limited towing experience with it, so far I am happy with it. I did a 300 mile round trip tow with 4,200 lbs and all was good. I'll be making my first long tow in a couple weeks. It'll be about 5,500 lbs and 1,400 miles round trip.
