brakes
Old Apr 9, 2017 | 07:40 PM
1948 F1dude's Avatar
1948 F1dude
brakes
1966 f-100 all new parts and hard pedal and no brakes???? new booster /master
Old Apr 9, 2017 | 10:27 PM
john jamieson's Avatar
john jamieson
Does the pedal have any movement? Single or dual master cylinder? If you have someone help you bleed the brakes, will the pedal move when you open a bleeder screw? How snug did you adjust the new shoes against the drums? (I'm assuming drum brakes)
Old Apr 10, 2017 | 03:19 AM
1948 F1dude
soft pedal with engine off drum brakes and have been bled with two people
have to check about single or duel
Old Apr 10, 2017 | 08:31 AM
svolpone's Avatar
svolpone
i've heard that this is caused by a bad booster. or maybe it's installed incorrectly? just because it's new doesn't mean it's good.
Old Apr 10, 2017 | 09:10 AM
AZSCAWPION's Avatar
AZSCAWPION
I've got a '65 with vac assisted brakes. Recently reworked everything and here's what I encountered. There were 2 mc listed by Ford originally (1 for power brakes 1 for manual). No one I know makes the one for power brakes and are pretty much forced to use the one for manual brakes instead. Visually, they look identical. The difference is the depth of the pockets. Power mc requires a deep pocket while the non power comes with a short pocket. This means that the pushrod is is in effect applying the brakes just by mounting the mc to the booster. In my case the solution was to shorten the pushrod by 9/16". Not saying yours is the same problem as we need more info from you.
Old Apr 10, 2017 | 11:32 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C5TZ-2140-A .. Master Cylinder-Use with or without Power Brakes / Obsolete
1965/66 F100 2WD / 1966 F250 2WD
Old Apr 10, 2017 | 01:01 PM
AZSCAWPION's Avatar
AZSCAWPION
In my endeavor I came across p/n C5TZ-2140-B (w/ booster) and C1TZ-2140-B (w/o booster) for the F250. I believe as you show they were different for the F100. I never did determine the physical difference for certain as no one I found stocks both. I suspect the difference is the pocket depth.
Old Apr 10, 2017 | 01:51 PM
NumberDummy
C1TZ-2140-B = 1961/65 F250 2WD/4WD without Power Brakes.
C5TZ-2140-B = 1965 F250 2WD with Power Brakes.
C5TZ-2140-A = With/without Power Brakes: 1965/66 F100 2WD & 1966 F250 2WD
Old Apr 11, 2017 | 02:46 AM
1948 F1dude
Thanks guys for the advise we will use this info and sort things out. I will post what we find was the problem.")
1972RedNeck
24
Jun 27, 2016 08:38 PM
guitarnik
Jun 21, 2009 10:49 PM
crack
Nov 6, 2004 08:32 PM
mxer201
Aug 20, 2002 09:35 PM
lsrjf
Nov 7, 2001 01:21 AM
