temp gauge question
Old Apr 8, 2017 | 10:42 AM
dthut's Avatar
dthut
temp gauge question
how long does it take the stock temp gauge to register?
ive swapped my 400 for a 390. and my engine seems like it getting hot fast but my temp gauge isn't reading. i think i'm just being paranoid and not letting it run long enough though.
Old Apr 8, 2017 | 10:49 AM
lasermike's Avatar
lasermike
When it's properly filled with coolant, mine can take a few minutes, maybe up to 5 before it's into the temp zone. The first two or three starts after draining and refilling it never came up and yet blew steam and then coolant out the radiator. A sure sign that it had air trapped behind the thermostat.
Michael
Old Apr 8, 2017 | 01:02 PM
meangreen92's Avatar
meangreen92
Is the sender on the new engine for a warning light rather than a gauge?
Old Apr 8, 2017 | 01:07 PM
dthut's Avatar
dthut
i've plugged it into the sending until right behind the dizzy. 390fe
is that the correct unit?
Old Apr 8, 2017 | 01:43 PM
meangreen92
Not if that 390 came out of a vehicle which had a warning light instead of a gauge. The senders are different between gauges and warning lights.
Old Apr 8, 2017 | 03:36 PM
dthut's Avatar
dthut
it came out of the same f series truck. 74 f350, and it has a dash temp gauge.
should be the same ya?
or is there a sending unit for the warning light and the gauge?
Old Apr 8, 2017 | 04:06 PM
lasermike's Avatar
lasermike
Different sender for light VS gauge.
Gauge is a variable resistance to ground, light is a switch that closes at setpoint. You can test from plug at sender back to gauge by grounding plug. Gauge will go full hot when grounded, full cold when not connected.
If you have an ohm meter, you can read from pin on sender to ground, Switch style sender will be open, gauge style sender will have some resistance, probably kinda high.
Michael
Old Apr 8, 2017 | 05:33 PM
Blue and White's Avatar
Blue and White
Fitting a simple mechanical temp gauge would tell you what is going on... at least as a diagnostic. A $10-15 Sunpro for example from your local AP store.
Also agree it may take a heat/cool cycle or two to get the air out... re-check coolant level after it cools each time.
Old Apr 8, 2017 | 05:53 PM
jakeharp's Avatar
jakeharp
390
The temp sender behind the dizzy should be legit.... My 390 will start to register after about 5 minutes or so, reaches operating temp with my 190 Stat after about 12-15 minutes-ish..... depending on shop temp..... I have a stat elbow fitting gauge sender that takes the 'open stat' temp also..... nice to have both, with the stock temp, your kinda guessing ..... but you should be seeing something after 5-10 mins..... If i remember correctly the sender color mark was green.....
Old Apr 8, 2017 | 11:35 PM
meangreen92
And don't use teflon tape on the sender's threads. The sender, being a one-wire deal, needs to ground to the engine. Shouldn't need anything on the threads.
3000gtman
Dec 19, 2016 10:08 PM
flashback max
Jun 27, 2011 11:22 AM
SLE
Dec 18, 2008 01:27 PM
msully005
1983 - 2012 Ranger & B-Series
Oct 28, 2006 11:42 PM
brelandt
Bronco II
Jul 13, 2006 09:03 PM
