Need help with PS swap - 96 e150
The unit is a reman oem part. Not sure If I should just keep turning the bolt to squeeze it in there. I don't want to snap the bolt. Should I get a new part or is this pretty normal? I swapped out a PS in an older ford van and I don't remember feeling this much resistance.
Also, do you guys recommend flushing the PS? The fluid that dripped out seems clean. Can anyone share tips on replacing the PS fluid? What do you guys use? PS fluid or ATF?
Thanks.
as to fluid, I would flush it out since you are in there already. It is part of maintenance anyway.
As to Type F fluid. That is what ford has recommended for years but,, here is a note from Ford chemicals:
Motorcraft® ATF Type F is recommended by Ford Motor Company. It is a high-static friction fluid developed for Ford automatic transmissions manufactured during the 1970’s and earlier. The special frictional properties of Motorcraft® ATF Type F ensure proper shifting in Ford transmissions that require a fluid meeting ESW-M2C33-F. It is also recommended for power steering systems in a wide variety of Ford Vehicles calling for a Type F fluid, built prior to Model Years 1996-1998. Check Owner Guide for proper application.
https://www.fcsdchemicalsandlubrican...smission+Fluid
I don't know what the difference is in 96-98.. Maybe Ford was changing over to something diferent in those years and it doesn't apply to all models
in addition to my 90 TC, I also unbolted the steering box in my 88 e150 last year to change a seal and the bolts were not hard at all to thread in..
I would take it back and try another gear box. Take the bolts and make sure they fit the second box.
Looking at Rock Auto's site, the gear box changes between 1886 and 1997. There is also a difference in the gear box depending on what size van and engine. Perhaps they gave you the wrong one...
MOTORCRAFT STG41RM {#F8TC3504ABRM, F8TZ3504ACRM}
FORD 4.9, 5.0, 5.4, engine
E-100 = 1982-1983
E-150 = 1982-1996
E-250 = 1982-1993
E-350 = 1982-1993
