Conversion information
Old Apr 4, 2017 | 03:08 PM
krekeler's Avatar
krekeler
Hey everyone, new to the site. I have been doing research and cant exactly find what I am looking for.
I am going to purchase a 1996 F-250. It is a 2wd and I am wanting to convert to 4wd. I have the mechanical ability, but don't have the knowledge when it comes to the parts. I am also getting a donor truck, but it is F-150 (89 or 90 model).
Am I going to run into any issues when it comes to putting the F-150 TTB front end in the F-250?
I know the gear ratio must match and I should be able to convert the front to an 8-lug, correct?
Also, I know that there is the option of buying a F-250 already 4wd but in my area, they are either in perfect condition and too expensive or completely rusted out and not worth purchasing. This truck in particular is in great shape and a very good price, along with the donor truck.
Thanks in advance.
Old Apr 4, 2017 | 07:52 PM
Willigaf's Avatar
Willigaf
Both trucks are in great shape? Or both come together at one great price?
Old Apr 4, 2017 | 07:58 PM
Red97350's Avatar
Red97350
You will be in much better shape getting a 250 or 350 for your donor. I honestly wouldn't even bother with the F150 running gear. JMHO.
Red
Old Apr 4, 2017 | 08:02 PM
Conanski's Avatar
Conanski
My advice, don't make this harder than it needs to be which means get the correct donor vehicle first. The correct donor vehicle in this case is another F250 with the same wheelbase and engine/trans combo, and that is because you not only need the front axle but the t-case, the transmission, and both driveshafts.
Old Apr 4, 2017 | 08:24 PM
krekeler's Avatar
krekeler
In response to the first reply, both trucks are priced well. The donor vehicle is junk in every aspect besides mechanical. It has a 302 and the F250 is 351W. Transmission and t-case will work fine. I will have to find a rear drive shaft. I'm just curious as to what issues I will encounter with the front end, if any.
Old Apr 4, 2017 | 08:51 PM
f1504x4driver's Avatar
f1504x4driver
Proud Pirate
As Conanski said, start with the right donor vehicle. The F150 used coil springs where most F250 trucks have leaf springs. A lot of extra work, time and money.
Old Apr 5, 2017 | 09:44 PM
krekeler's Avatar
krekeler
Ok, I guess I was pretty vague in my original post so I will provide more details.
The F-250 is a 1996 Extended Cab Long Bed.
351W
Automatic
2 Wheel Drive
Front Twin I-Beam
Coil Springs in front
The F-150 is between a 89-91, not real sure.
5.0
Automatic
4 Wheel Drive
TTB Front
Coil Spring Front Suspension
I am asking if the front components will bolt directly in to the F-250. I know that I will need to find a rear drive shaft which isn't an issue and I should be able to convert the front to an 8-lug, correct?
I understand that I can just purchase an F-250 as a donor but at the moment, the F-150 is available for a good price. $300 and it runs and drives and the 4-wheel drive works good, but the body is shot. I cannot find an F-250 that runs and drives for that price.
Old Apr 5, 2017 | 09:46 PM
krekeler's Avatar
krekeler
351W
Automatic
2 Wheel Drive
Front Twin I-Beam
The F-150 is between a 89-91, not real sure. Single Cab Short Bed
5.0
Automatic
4 Wheel Drive
TTB Front
Old Apr 5, 2017 | 10:24 PM
Willigaf's Avatar
Willigaf
Can you park them next to each other for a while and inspect? I would think the first hang up is going to be where and how the springs mount on the frame side. As for an 8 lug Dana 44, I think that used to be a factory offering but I'm not certain. Yeah, late 70's I'm pretty sure. So maybe parts exist for that.
I think you're not getting the advice you want because nobody wants to touch this with a ten foot stick. I imagine it similar to how most folks must have looked at the first guy to convert a 2wd to 4wd but starting with the right parts. How about skipping the 250 altogether and fixing up the 150, or converting another nicer 150 2wd to 4wd? Or just finding a nice body for the 150?
Then sell it for a profit, hopefully, and buy a nice 250. Or expand your search area. Mine ran and drove with some issues but cost $1500 and didn't have any rust before I owned it.
Old Apr 5, 2017 | 10:27 PM
Willigaf's Avatar
Willigaf
Hell if you have a nice welder and know how to use it I say yes. You can make it work. Aaron Kaufman put an ecoboost in a pantera. Anything is possible.
Old Apr 6, 2017 | 12:00 AM
raystankewitz's Avatar
raystankewitz
If you poke around, you'll find threads on eight-lug D44s. What I don't know is whether you will be able to physically bolt the TTB to the F250 frame.
It's one of those swaps that is unproven and uncommon.
Old Apr 6, 2017 | 10:08 AM
Conanski's Avatar
Conanski
You need a transmission too, the F250 has the E4OD so you need another truck with a 4wd version of the E4OD.
Old Apr 6, 2017 | 10:48 PM
BLK79's Avatar
BLK79
I considered doing this very thing to a 97 CCSB. The 1/2 ton coil TTB stuff SHOULD be pretty much a direct bolt in. Converting to 8 lug requires Chevy parts, from a D60 if I remember correctly. As mentioned, trans/transfer case etc which you apparently have.
Old Apr 6, 2017 | 10:50 PM
BLK79's Avatar
BLK79
It was a beautiful 460 truck, decided to sell it and keep the much rougher 92 4wd I've had forever.
Old Apr 7, 2017 | 01:02 AM
raystankewitz
Some of the F250 ttbs were 8 lug D44's. Might not be too common but they're out there. That way, you don't need no stinkin' Bow-Tie parts.
