Seatback foam source
Old Apr 4, 2017 | 10:18 AM
1984montemaniac's Avatar
1984montemaniac
Ok folks, I ordered new seat cushions from American cushion and an upholstery kit from NPD. They inform me the seat back foam is not available. I thought I read on here the bench seats interchange to 1996 or so. If this is true, are there any dealers that may have seat foam? I will try tasca Ford...
Any thoughts suggestions are appreciated....my seats smell like mouse **** and I cannot put my senior mother in the truck smelling like that...
Plus I may barf.....
Old Apr 4, 2017 | 10:26 AM
78 PEB's Avatar
78 PEB
The seats themselves will interchange......just use the seat tracks from your original.....I do not know however if just the foam will interchange.
Old Apr 4, 2017 | 10:34 AM
fetusgrinder's Avatar
fetusgrinder
Hydrogen peroxide will neutralize the urine. it may also bleach whatever it touches, so keep that in mind. I had good luck using it in a pet ruined rental house. Just soak, and let dry. Repeat if needed.
Old Apr 4, 2017 | 10:35 AM
hokiehighboy's Avatar
hokiehighboy
If you are ok with OEM used...your local JY, if they have a dent, may still have the bench seat in it. The foam for the back usually holds up pretty well.
Old Apr 4, 2017 | 03:10 PM
HoustonDave's Avatar
HoustonDave
You can also buy foam sheet on-line and cut it to match the seat-foam profile with an electric carving knife. Probably cheaper and allows you to custom-make the seat back (like maybe if you want the back to be firmer than the seat, or want a little more lumbar support.)
Old Apr 4, 2017 | 05:43 PM
ClassicKidNick's Avatar
ClassicKidNick
See if a local upholstery shop can get you some new foam. They may cut to fit, etc. I have a local guy who does boat seats and has always got me the exact foam I need before I re-upholster.
maschronic
Jul 22, 2007 02:31 PM
59flatbedford
Jul 3, 2006 02:28 PM
wiscovan
Aug 3, 2003 09:28 AM
Jim242002
1997 - 2003 F150
Apr 10, 2003 02:43 PM
