Front tow hooks?
Old Apr 1, 2017 | 09:09 PM
anthonym92's Avatar
anthonym92
Front tow hooks?
Hey guys are there any locations where I could mount front tow hooks and if so where do I buy them? Can't seem to find any online
Old Apr 1, 2017 | 10:41 PM
f1504x4driver's Avatar
f1504x4driver
Proud Pirate
If you don't have a front sway bar, you can mount them to the sway bar mounting plates. You can find them at any off road supplier and many auto parts stores.I bought mine from 4 wheel parts.
Old Apr 2, 2017 | 09:05 AM
'89F2urd's Avatar
'89F2urd
Just about any late model truck has beefy tow "D" hookups that are solid as a ****. Junkyard, frame bolt.
Old Apr 2, 2017 | 01:30 PM
Diesel_Brad's Avatar
Diesel_Brad
To do it right way, you would need to put a front receiver hitch on. it will tie the two frame rails together and give a central point of pulling from
Old Apr 2, 2017 | 07:59 PM
jason90f150's Avatar
jason90f150
You could get tow hooks from a 2008-2010 Superduty. The bolts are M12-1.75. There's a plate attached to it which is like a mirror image of our frame so you might have to cut some of it out. Then weld in the 3 nuts inside the frame, cut holes in your bumper, then done. I'm doing this to my truck soon and that's my plan.
Old Apr 2, 2017 | 10:50 PM
BLK79's Avatar
BLK79
Front receiver hitch as mentioned is easy to install, at least on 4x4. I got mine thru etrailer shipped for about $150.
Old Apr 3, 2017 | 09:01 PM
dixie460's Avatar
dixie460
I had mine mounted to my frame rails (just drilled right thru the crunchy part (crumple zone)) but I also had a winch installed which also served to tie the frame rails together as Diesel_Brad mentions.
Mine came off a 97-04 body style F-150 4x4.
Old Apr 3, 2017 | 09:58 PM
GoinBoarding's Avatar
GoinBoarding
I welded up a 4" channel with tabs to fit 10k clevis onto. Later added a receiver. It's handy as heck when wheeling or moving a big trailer into a tight spot. I can lift the front of the truck with a hilift, and have reliable front tow points. The bumper needed the center hole enlarged for the receiver but this keeps it from killing the approach angle. Here's the best picture I have of it. Taken with my old potato camera* ;-)
cowman435
Feb 11, 2011 05:50 PM
CCBennett_1
2004 - 2008 F150
May 13, 2009 06:36 PM
MBBFord
Offroad & 4x4
37
May 6, 2008 04:25 PM
81redbronco
1978 - 1996 Big Bronco
Oct 22, 2003 03:53 PM
