New F250 with a knocking engine..... decoding help please!
Old Mar 27, 2017 | 09:57 PM
62FE4x4's Avatar
62FE4x4
We just came across a 1980 F250 really cheap. The previous owners have done a lot of work to the engine, etc. The engine started knocking so they sold it to me. I am looking to find out what kind of axles, gear ratio, transmission, etc. it has. I have a Bronco of the same year with a blown transmission I thought about using. The engineis a 429 out of a 1972 police cruiser. Any decoding would be a huge help. Truck is rust free and in great shape other than the engine which I intend to rebuild. All feedback appreciated.....
Old Mar 27, 2017 | 11:05 PM
Gary Lewis's Avatar
Gary Lewis
Hard to read, but you can decode it all right here: Certification Label - ???Gary's Garagemahal.
Old Mar 28, 2017 | 07:30 AM
62FE4x4's Avatar
62FE4x4
Interesting
The 5th digit of the v.i.n. is supposedly the assembly plant, but there is no R on that chart
Old Mar 28, 2017 | 07:38 AM
Gary Lewis's Avatar
Gary Lewis
You are right. But this list says that they had a facility in San Jose that was the R: https://en.m.wikipedia.org/wiki/List_of_Ford_factories. I'll update the web site.
Old Mar 28, 2017 | 07:45 AM
62FE4x4's Avatar
62FE4x4
Yep
That makes sense. The truck is located in New Mexico. It was originally a 351M truck so that manual tranny setup should work perfectly. I have have a cert label to decode on the Bronco forum.
Old Mar 28, 2017 | 07:49 AM
Gary Lewis's Avatar
Gary Lewis
You should be able to use my decoder on the Bronco.
Old Mar 28, 2017 | 08:19 AM
62FE4x4's Avatar
62FE4x4
I can't quite figure out the DSO code. There is a 6 code and a 2 code system, but mine has a 4 code....
Old Mar 28, 2017 | 08:25 AM
Gary Lewis's Avatar
Gary Lewis
Since it says "1980" it looks like that's just a year rather than District Sales Office. 1980 was an odd year for VIN's as well as electrical stuff on these trucks.
Old Mar 28, 2017 | 10:05 AM
62FE4x4's Avatar
62FE4x4
Yep
You are correct. The Bronco also has a DSO code of 1980 as well....
Old Mar 28, 2017 | 10:13 AM
Gary Lewis's Avatar
Gary Lewis
So, you are building an '80 Bronco? That's the era Bronco I've been watching for. What are your plans?
Old Mar 28, 2017 | 12:06 PM
62FE4x4's Avatar
62FE4x4
It has a C6 with a bad tranny. I want to take the manual setup from the F250 and put it in the Bronco. When I get the 429 rebuilt I want to put that in there as well. Bronco is rust free with a/c and cruise. What made you want a 80 instead of a 96 or a 78 for instance?
Old Mar 28, 2017 | 12:12 PM
Gary Lewis's Avatar
Gary Lewis
Actually, my preference is an '81 as it has the later wiring but still has the simple grille w/o the . But, an '80 is very very close.
As for a '96, I prefer the Bullnose look. And the early Broncos are smaller, but a '78 or '79 would be an option. However, since I know the Bullnoses and have the documentation on my web site that's my preference.
Having said that, I'm talking to another FTE'er about his '87 Bronco. It needs an engine but may otherwise be servicable. Anyway, I'm watching for "the right" Bronco to be a project to share with my son.
Old Mar 28, 2017 | 12:20 PM
62FE4x4's Avatar
62FE4x4
I have always liked the bullnose as well, and I have owned several over the years. I had a 82 Bronco about 2003 with a 300 I6 and a 3 speed OD Manual. That truck was incredibly reliable. I still have a 85 F350 Crew Cab 4x4 with a 6.9 as well as a 67 Bronco with a 289. Both have been outstanding trucks
Old Mar 28, 2017 | 12:24 PM
Gary Lewis's Avatar
Gary Lewis
As you can see from my sig, I currently have two Bullnoses. But, I just sold another '81 called Rusty about 10 days ago, and I had an '82 earlier. Plus I've owned another '82 and an '85 that were parts trucks. So, all in all I've owned at least 6 of them in the last 6 years.
Old Mar 28, 2017 | 02:21 PM
62FE4x4's Avatar
62FE4x4
Further....
After studying that cert label chart it actually looks like the dso code is above the block where 1980 is stamped....
