welding questions
Old Sep 2, 2003 | 07:31 AM
theologian's Avatar
theologian
welding questions
Ever seen a tailer fire.... Aluminum burns well.
Theo
Old Sep 2, 2003 | 09:26 AM
jbalestri's Avatar
jbalestri
welding questions
Simply, yes, it can be done. Is it cost effective? I doubt it. A welder or machine shop than can do aluminum will charge $100/hr with either .5 or 1 hr minimum. For $15 you can go to home depot, buy some stainless or aluminum bracketry, epoxy, and bolts and you are done, minus drilling two holes.
Old Sep 2, 2003 | 02:05 PM
haroutd's Avatar
haroutd
From: I'm lost somewhere in NJ -- can someone please find me?!?!?!?
welding questions
Have you guys ever heard of a product called alumaloy or alumaweld? www.alumaloy.net http://www.virtual-adnet.com
I've seen their info-mercials on TV. It seems to be a sort of solder used for repairing/attaching aluminum. Apparently, all you need is a standard propane torch to work it. I spent about a minute on the web researching it, and from what I understand it is effective. You need clean parts (no contaminants or the bond will be poor), and have to seal the weld if it will be exposed to corrosive aluminum. I don't work with this kind of stuff, so I can't really comment. But I figured I would throw this option on the table in case it's of any use.
tozir
13
Jul 18, 2012 02:10 PM
websthes
Dec 31, 2010 03:49 PM
court1100f
18
Dec 29, 2010 10:12 PM
jdmorg
Feb 3, 2006 01:12 PM
