1949 F1 BELL HOUSING
I am building a 1949 f1 with a flathead v8. it has a 59t transmission with a stamped steel bell housing. when installing bell housing it comes in contact with 6 corners of 11 inch clutch just inside where rear cast adapter plate bolts up. anyone know if my clutch and flywheel are wrong. i am wondering if the bell housing has been changed. should it be cast?. does it still use adapter plate? trans does not have an integral bell housing on front.
