Deep Philosophical Question About a Tired Engine
Old Mar 30, 2017 | 07:57 PM
Franklin2's Avatar
Franklin2
Originally Posted by reamer
Define "good" oil pressure. 351's have "low" oil pressure from the get-go. and mine has had the oil needle on the "N" on "normal" for years.
Oil pressure is stronger as it warms up, but once up to temp is up to "normal," the oil pressure needle sits on the "N"
I was told years ago, 10lbs, 40lbs it does not matter, the heads are getting lubed ........
I don't want to be too critical, but if you are still staring at the stock oil pressure gauge worrying about your oil pressure, then you must not be too concerned about it. The original gauges are lousy.
Old Mar 30, 2017 | 08:32 PM
reamer's Avatar
reamer
Correct on the OEM gauges.... No noise from the engine, not concerned, when it pops, in goes a new one, (Granted, it's easy to say this when it's NOT the daily driver)
Old Apr 1, 2017 | 11:12 AM
jmarks99's Avatar
jmarks99
ford v8s are usually ok if you have at least 4PSI oil pressure. Low oil pressure at operating temp usually denotes bad bearings
Old Apr 1, 2017 | 11:57 AM
Beechkid's Avatar
Beechkid
The SBF's are excellent engines that if properly maintained will just keep running no matter what...........our mustang that has been in the family since new (1965), had 210k miles on it untouched when I bought it from my parents back in 86......when we fired it up, she ran a smooth as what I can remember.....
SBF Internal engine failure, never known for that unless it's been abused or performance wise push beyond it's limits........as an fyi- the SBF's for most of the common performance builds, never needed 4 bolt mains as compared to the chevy's because their design was very strong!!!!!!!!!!
The iron heads will take a bit of abuse as well......very rare to hear of a head gasket failure unless there were some real significant issues or real-dumb type abuse!
Old Apr 1, 2017 | 12:10 PM
reamer's Avatar
reamer
Mine is a Spring-Summer-Fall truck, most "abuse" it gets is spilled Ice cream on the tailgate from the kids (or wife)
It runs fine at 75MPH on the highway with the ZF
Old Apr 2, 2017 | 12:38 PM
Brnfree's Avatar
Brnfree
I agree that an old motor should start knocking, progressively louder over time, before going to pieces... but a more likely failure scenario for an old motor might be a flat cam or bad valves, which would degrade performance over time but probably not leave you stranded.
If you were miles away with a knock and low oil pressure you could try thicker oil, or some kind of additive, to limp it on home.
In many ways I prefer the old school Fred Flintstone pre fuel injection, pre computer carb and distributor set up because there are many ways to jumper wire and jury rig things to bring it on home, whereas I'd be hard pressed to figure out and fix a modern fuel injected computerized engine management system out in the wilds.
So what could fail suddenly leaving you stuck? Fuel pump, timing chain, u-joints. What else can you think of?
I've read the OP's old post on an external electric fuel pump set up and I've been meaning to add an external electric fuel pump that I could instal in an emergency to my on board spare parts inventory. Otherwise my double roller timing chain and gears are only two years old and my u-joints have grease zerks and I keep them lubed.
Otherwise, like you say, I could play it safe and leave it parked... but what's the fun of that? Big dog was made to run and life is too short to stay on the porch.
1986F150six
Aug 13, 2018 11:31 AM
69'er
Nov 30, 2013 02:59 AM
brad1975
1983 - 2012 Ranger & B-Series
13
Oct 2, 2009 07:27 AM
78oldsmokey
Feb 21, 2004 03:11 PM
bikerwolfie
May 11, 2002 02:20 PM
