2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Update to increase power?
  #31
Old 03-27-2017, 07:30 AM
Top_Speed1's Avatar
Top_Speed1
Top_Speed1 is offline
Originally Posted by 2017FSD
Our fords are still ridiculously powerful in stock form. No need for power upgrade but wouldn't tell the tech to not install it. A little more torque for my 37inch tires would be nice
So you're not so 'confident' about this new power upgrade now
  #32
Old 03-27-2017, 11:11 AM
troverman's Avatar
troverman
troverman is offline
The upgrade from 390/735 to 400/800 basically did not change the performance of the truck in real life. Here's Car & Driver's review of pre-flash and post-flash: 2011 Ford F-250 Super Duty King Ranch Crew Cab 4x4 Diesel ? Instrumented Test ? Car and Driver
I think a flash today moving the truck from 925 to 1000lb-ft or from 440HP to 450HP would produce, once again, negligible results in real life. Perfectly content at the current power levels.
  #33
Old 03-27-2017, 11:17 AM
fordmantpw's Avatar
fordmantpw
fordmantpw is offline
I'd rather have 1 more MPG than an extra 60 HP and 75 ft-lbs of torque. If I could get both, though, I'd be ecstatic!
  #34
Old 03-27-2017, 11:28 AM
das_16's Avatar
das_16
das_16 is offline
I have access to IDS and we checked last week and there were no updates.
  #35
Old 03-27-2017, 12:42 PM
troverman's Avatar
troverman
You can, it involves a sawzall and a straight piece of exhaust pipe
  #36
Old 03-27-2017, 12:49 PM
fordmantpw's Avatar
fordmantpw
I forgot to add in the little part about not voiding my warranty.
  #37
Old 03-27-2017, 05:30 PM
UGA33's Avatar
UGA33
UGA33 is offline
True story right there!!
  #38
Old 03-27-2017, 07:25 PM
Rutcutter's Avatar
Rutcutter
Rutcutter is offline
Guy's after driving it again on the same roads I travel everyday to compare I've put about 40 miles on it between all the job sites and back an forth to lowes etc..
Honestly the truck feels stronger an shifts better etc. Maybe the early trucks programs that rolled out wasn't as "refined" as the newest calibrations.
  #39
Old 03-27-2017, 07:32 PM
System's Avatar
System
System is offline
Prolocutor
Received 1,200 Likes on 574 Posts
That could be part of it along with the trans relearning.
  #40
Old 03-28-2017, 07:17 PM
Rutcutter's Avatar
Rutcutter
Could be but sure does feel a lot better... Epic have you checked yours out to see if there is an update for it?
  #41
Old 03-28-2017, 07:21 PM
System's Avatar
System
System is offline
Prolocutor
I checked a little higher up the line on this. There is no power increase flash and as of now, Ford's stance is there will be no power increase until the next refresh including a 10 speed trans. Likely in 2020.
  #42
Old 03-28-2017, 07:26 PM
oklarado's Avatar
oklarado
oklarado is offline
nice it'll be trade in time and I can get an updated gas engine and 10 speed. I want 15mpg, 400hp and 500tq. Lol
  #43
Old 03-28-2017, 07:30 PM
fordmantpw's Avatar
fordmantpw
Somebody tried to tell y'all a 10 speed was coming!
  #44
Old 03-28-2017, 07:51 PM
Rutcutter's Avatar
Rutcutter
Well that's what they have to tell ya anyway.. Until someone posts a dyno before and after the update will tell the tell..
Could be a "soft" update to keep it on the down low.. Just sayin' I put 5700 miles on it and now with this new program it feels stronger and more refined on the rout I take everyday.
Glad I had the update done...
  #45
Old 03-28-2017, 07:54 PM
oklarado's Avatar
oklarado
oklarado is offline
you still believe that??? Maybe your truck got a top secret factory test tune, maybe Will Farrell took the restrictor plate off......
Quick Reply: Update to increase power?
