Has anyone added a cabin air filter to their 2011+ Super Duty?
My pickup is in very dusty environments a lot. I would imagine my entire system (ductwork, doors, evaporator, etc) are currently affected to one degree or another by that fact.
I think I'm going to have my Ford dealer tear the dash apart and blow the vents out, replace the blend door actuator, clean out or replace the evaporator, and anything else they might find to get the system running well again. After that though, I'd like to prevent it from happening again.
Has anyone else done anything like that?
Thanks.
Thanks.
I never understood why ford never installed a cabin filter when the designed the first generation SD in 1999...GM and dodge have cabin filters since 1996 or 1997
will say I pulled my blower motor and duct work open this summer on my 2004 and it was nearly SPOTLESS not one leaf or bug not even dust layer on the inside. I guess always shutting g off the HVAC system when I see a big cloud of dirt or something along them lines has really helped after all these years
We have a 2010 F350 that the evaporator plugged up on. I took out the blower motor under the dash and used a shop vac to try and get the junk out of there. That didn't work well, so I pulled the glove box lid out, and drilled a hole in the air box. I could get an air wand in there to blow it out. I used a shop vac still to help keep the dust out of the cabin. Then I plugged the hole off with one of those red plastic plugs you can cap a hose off temporarily with.
It would be nice to have a cabin air filter. It gets plugged easily on the farm.
I watched a YouTube video on this subject a while back but now I cant find it. Owner of a 3 year old CD Super Duty used in a landscaping business had a plugged evaporator. The dealer told him it was plugged from running the ac on recirculate and picking up dirt from the inside of the truck. Dealer told him to make sure his employees clean their clothes before entering truck.
Yes sir I have a filter. I can't "sell" it on this forum tho. But you are more than welcome to call me 432-234-9880 . Or text.
I have seen the kit that goes outside in the windshield cowl area. http://www.cabfreshfiltercompany.com/?s=19811
and there was this article: http://www.cabfreshfiltercompany.com...ckups-1997-up/
https://www.ford-trucks.com/forums/1...ir-filter.html
https://www.reddit.com/r/DelSol/comm...nder_the_cowl/
