Bronco II Ford Bronco II
Drive Shaft Question
Old Mar 17, 2008 | 07:10 PM
mudslinging79's Avatar
mudslinging79
could be low in fluid or fluid may need changed. to check the fluid, park on level ground with the motor running, tranny in neutral. be sure to warm up the tranny to operating temp first. also look at the fluid, if it smells bad, or is brown then the tranny fluid needs to be changed, and while the pan is off may as well change the filter.
Old Mar 17, 2008 | 07:19 PM
f100guy's Avatar
f100guy
if you don't have the tranny serviced regularly evey 20,000 miles, i would urge you to not do a flush or change filter. if the fluid looks,smells good, you may be ok.
Old Mar 17, 2008 | 10:02 PM
mudslinging79
does the auto trannys in the b-2 have bands that one can adjust like whats in the older plymouth auto?
Old Mar 18, 2008 | 01:28 PM
f100guy's Avatar
f100guy
i believe so but i have not adjusted anything on a tranny so don't take my word for it.
