Aftermarket Products
Sponsored by: Worksport
CryO2 Systems
Old Aug 31, 2003 | 05:55 PM
AMVX's Avatar
AMVX
Lightbulb CryO2 Systems
Okay, I'm planning on purchasing a K&N charger intake. I read in another post that is doesn't allow a lot of cold air to enter the engine, so I got an idea to install a CryO2 fogger in front of the filter. Would this work? Let me know what you think.
1996 F150 XLT 4x4
5.0 EFI, BFG A/T's, custom built side exhaust...so far
Old Oct 8, 2003 | 09:22 AM
oldtarget's Avatar
oldtarget
CryO2 Clarification
Regarding the CryO2 system in the configuration you are talking about. The CryO2 system is NOT like nitrous, it can not be ingested into the intake because it uses CO2 which will deprive the engine of O2 and stall the motor. You can still use the the CryO2 Air Intake segment after your filter and before any mass airflow sensor (to register the cooler air). The CryO2 system is designed for drag racing only right now as a 5lb tank will only cool for about 2.5 - 3 minutes.
The system is pretty trick but you must make sure that the CO2 vents away from the air intake! I hope this helps.
Matthew
Old Oct 8, 2003 | 09:55 AM
CobraXP's Avatar
CobraXP
Before I would use the CryO2 system, I would fab a new intake tube and run the filter to a different location so it would be able to get cooler air. Like oldtarget said, they only last a few minutes and you have to be very careful on the location of the spray.
I would like to welcome you both to FTE!!!
Old Oct 16, 2003 | 10:31 PM
AMVX's Avatar
AMVX
Thanx ya'll. I'll try and figure something out. Let me know if you hear about anything similar to what I am doing. Thanx again.
---AMVX
