Differential HELP!!!
Old Mar 23, 2017 | 05:02 PM
Dallas759's Avatar
Dallas759
Im new to replacing my rear diff. gasket (since its leaking pretty bad). What are the proper torque on the bolts, and how much gear oil should i use? Whats the best gear oil? Do i need to add any additives to the oil?? Kinda above my head here but feel confident i can do it!! HELP PLEASE!
Old Mar 23, 2017 | 05:43 PM
pirate4x4_camo's Avatar
pirate4x4_camo
Should be all your answers
Old Mar 23, 2017 | 05:45 PM
pirate4x4_camo
Doh, Can only upload 1 pic at a time.... here ya go
Old Mar 23, 2017 | 05:47 PM
Dallas759's Avatar
Dallas759
Thanks! That does help a lot!!
Old Mar 23, 2017 | 05:50 PM
pirate4x4_camo
Fwiw, Diff cover doesn't use a gasket from the factory. They use RTV
Old Mar 23, 2017 | 06:03 PM
Dallas759's Avatar
Dallas759
Ok that does help!! I was gonna buy one from NAPA
Old Mar 24, 2017 | 05:45 AM
jcthorne's Avatar
jcthorne
Having done the RTV thing for years, its a PIA as it needs to sit overnight to cure before you can put the oil in.
This time around I used the Lube Locker print o seal gaskets. EASY. No wait, no mess, no leaks and reusable. Well worth the few bucks.
Old Mar 31, 2017 | 02:52 PM
Stewart_H's Avatar
Stewart_H
I waited 5 minutes to let it skin up and put the diff cover on. Have done it that way for years with RTV without a problem.
You let it sit too long.
Stewart
Old Apr 1, 2017 | 09:22 AM
Blakshukvw's Avatar
Blakshukvw
Same here. Let it skim 20 minutes and fill
can0fspam
Aug 16, 2018 02:30 PM
mikerans
Mar 19, 2013 05:36 PM
sawyersvintage
Aug 12, 2011 07:19 PM
6LPSD
Jun 10, 2010 04:13 PM
