Just got my birthday present
#31
Engine Pics
Alright, got some pics today after I cleaned out a bay in my shed.
It does have the air cleaner box, I just took it off to get these pictures.
Odd thing I found was this attached to bottom of air intake and it was loose and pulled right out without much persuasion.
It was under the manifold and came right on off.
Right now my plans are to do a tune up first, then repair/fix/whatever the exhaust manifolds. Once that's done and the engine is satisfactory I'll start working my way through brakes, then 4wd, then I'll worry with appearance.
I believe someone had asked for pics of the engine (posting this from my phone so I apologize for not looking up who) to determine how well of a swap had been done. The smog pump is still in place although there is no belt turning it. I'm wondering how much of a pain it would be to go ahead and remove all that stuff? No emissions here in NC plus its farm tags and in 2 years no inspection at all will be necessary.
Thanks to all all who look and comment. Any help is appreciated!
#32
The thing that came off is the pre-heat to the air inlet. Read this: Air Cleaners - ???Gary's Garagemahal
#33
#34
#35
Thanks Gary.
I didn't get the best picture of it I see now, but the bolt holes are rusted through on the manifold piece. Are these something that can be found aftermarket or do I need to find a junkyard somewhere? There's not many near me that I've found is why I ask. What term would I search for if I go to the trusty google machine to find it?
#36
The official name is "carburetor air cleaner air duct shroud", but I doubt anyone but Numberdummy knows that. Anyway, it is 9A603 in the illustration below, and you can pic out the part number from the second snippet. However, I don't know what exhaust manifolds are on that engine, so if they aren't the original truck ones then the shroud might be different.
#37
#38
#39
The hard part to make is the part the hose hooks to. If you were to remove the rest and take that curved part you could then bend sheet metal and drill holes to hold it put that hose piece on the sheet metal and be back in buss.
Dave ----
#41
Anyone ever used a dash cover on a beat up dash pad for these trucks? Mine is pretty ratty (cracks, speaker part is pretty much a speaker hole at this point) and as I was sitting in the office on the phone today I looked at the old google machine and found this:
https://www.carid.com/1984-ford-f-15...-53339013.html
Got me to thinking about it, and for a short-term fix, that's a lot cheaper than the $300+ option from LMC truck that's supposed to be a new dash pad. LMC also has a dash cover like the above link, and the price is within $20 of the linked one, the picture just isn't as good online.
Thoughts/opinions/prayers/advice welcome.
Just wondering my way through this deal, hoping not to wander into something I need to stay away from.
#44
They are a huge improvement over a cracked dash. And, unlike Rusty's, if you put one on that's the same color as the dash pad you probably won't even notice it.
Now for a suggestion of how to put it on: Carefully.
Seriously, the first time I put it on Rusty I did so while the pad was on the truck. That didn't work well and the cover wasn't down evenly. So, the next time I took the dash pad off and glued it down carefully using their glue. However, even with all that it didn't stay down evenly.
So, next time I'm going to pull the dash pad and glue it on with 3M spray adhesive.
