Rebuilt engine, cant get it started. 1995 7.3
05-04-2017, 12:20 PM
on
Quote:
Originally Posted by
z31freakify
On the pickup tube did you replace the rectangular seal? Fill your oil rails and HPOP with oil and try to start it.
yeah I put a new seal on pickup tube. Oil rails are full, so was hpop. Did you say there shouldn't be any oil in the Hpop gear? Behind the EBPS?
05-04-2017, 12:23 PM
The gears should be oiled if your getting LOP, but no oil like your hpop reservoir
05-04-2017, 12:36 PM
on
z31freakify
it does seem like there is some oil on the gear, not much.
05-04-2017, 01:04 PM
That's normal, have you tested the HPO rails with a manual gauge to see if your building pressure.
05-04-2017, 01:11 PM
on
z31freakify
i will test that when I get it back together.
Another question: I just removed the Hpop gear, it was torqued to spec when installed. Is there a possible chance it was just spinning the gear and not the pump??
Is there a sure way to install this gear? There is no key to hold the gear in place....... lame
05-04-2017, 01:47 PM
If it was torqued right, it should not spin.
05-04-2017, 02:01 PM
if that was a new gear, looks like it has slipped some
What did you tighten it up to?
05-04-2017, 02:54 PM
on
knottyrope
yeah it does look like it slipped.... I cleaned everything and I re torqued to 100 lbft
It's odd I'm getting a p1298 code when buzz testing..
https://youtu.be/f_74mWDJgYg
05-04-2017, 03:00 PM
if IDM is bad enough for the PCM, that might be why it don't start
got a spare one?
05-04-2017, 03:09 PM
on
knottyrope
got a spare one?
well, I sent my pcm and idm into swamp diesel. They suggested a new idm. Pcm tested out good. Buzz test passed the second time. Wierd.
Seems I'm not getting much pressure in my Hpop. Going to go get a manual gauge..
https://youtu.be/6zyg0gp_mkY
05-04-2017, 04:02 PM
inside HPOP reservoir is only LPOP pressure, once it leaves the pump depending on IPR voltage you get HPOP pressure
Check IPR voltage at the connector while cranking
05-04-2017, 04:16 PM
on
knottyrope
Video shows voltage, top right. I'm getting 24+ while cranking now
05-04-2017, 04:40 PM
on
Latest video, not really sure where to go from here
05-05-2017, 08:57 AM
when you remove IPC, the laptop reads default values from PCM
Time for a pressure gauge 0-4000 PSI to be connected.
Do you have a meter? checking the voltage of IPR is still needed. the screen voltage cant be trusted fully.
05-05-2017, 09:31 AM
on
knottyrope
trying to find a tutorial on checking the ipr voltage. Is this test with key on? Or turning over? From battery ground to red wire on ipr while connected? Yes I have a multimeter
