Mixing Coolant
Old Mar 17, 2017 | 08:59 PM
InmatesRunThePlace's Avatar
InmatesRunThePlace
Mixing Coolant
Hey guys,
Just got the Excursion back from the shop and had the odd #'d injectors replaced. Truck runs great, but looking at the invoice they charged me for ONE gallon of Mopar gold coolant.
Now I've been running the Zerex Red EC-1 ELC coolant for a couple of years and I know that one gallon of coolant isn't enough to do a full flush, so they must have mixed it. I'm going to assume that the two are incompatible. Back me up on that before I go back and have them do a fluid flush and change for me?
Thanks!
Chris
Old Mar 17, 2017 | 09:46 PM
nmclella's Avatar
nmclella
I've heard different stories on the dangers of mixing coolant, but as far as I know they're just stories. I would make them flush and refill with the proper coolant either way since that is what they should have done in the first place.
Old Mar 17, 2017 | 10:14 PM
05MilMachine's Avatar
05MilMachine
I believe the chemical makeup matters more. If they are both Hybrid Organic coolants, shouldn't be an issue. But mixing organic coolants with non organic can cause trouble. I would research the coolants and see what they are made up of. I would also ask them why they chose that particular coolant. That might be the answer you need to make up your mind.
Old Mar 17, 2017 | 11:07 PM
InmatesRunThePlace
Thx for the feedback. Here is what I found on the Zerex EC1 stuff
http://content.valvoline.com/pdf/Zer...l_Bulletin.pdf
ZEREX™ Extended Life HD is compatible
with major long life and conventional brands of ethylene
glycol based coolant. However, long life characteristics may
be diminished by mixing with light duty or non-fully
formulated coolants.
And this is the Mopar stuff they apparently used
http://www.moparinternational.com/as..._19Dec2014.pdf
Ethylene glycol-based five-year formulation to prevent freeze-up and boilover
while inhibiting corrosion. Only for vehicles factory filled with 5-
year/100,000-mile coolant
Zerex has organic inhibitors and the Mopar stuff doesn't. That's how I read it. Probably not critical, but they should have known better.
Old Mar 17, 2017 | 11:25 PM
pirate4x4_camo's Avatar
pirate4x4_camo
The problem I see is the zerex is a OAT Coolant and while some of the mopar coolants are also OAT and would be compatible I don't see mopar "gold" listed on that link so it is unknown if the mopar gold is a OAT coolant or not.
Old Mar 18, 2017 | 12:39 AM
Stewart_H's Avatar
Stewart_H
This is exactly correct.
To the OP, If they had mixed in either a traditional "green" Ford coolant or the Ford "Gold" hybrid coolant, you wouldn't have to worry.
However, because they used a non-Ford coolant, I would demand reimbursement for a complete flush and refill of your Heavy Duty OAT "red" coolant. But I'd do the work myself.
No, there's no issue. Not if you mean mixing a traditional "green" coolant with either a Hybrid OAT coolant (like the Ford "Gold" or Zerex G-05) or a "red" Heavy Duty OAT coolant. All that will happen is, if the too much of the "green" or "Gold" is added to the "red" then the OAT "red" will lose it's ability to protect cavitation through it's acid based technology.
Yep, I'd insist on it.
Stewart
Old Mar 19, 2017 | 11:05 AM
InmatesRunThePlace
Thanks guys.
The stuff they used is on the second link - 68048953AB per the invoice.
I pulled some out of the degas bottle and it is an orange color instead of the red. So they def mixed it in. I'll give them a call tomorrow and see what they'll do.
Old Mar 19, 2017 | 11:34 AM
Stewart_H's Avatar
Stewart_H
Thanks guys.
I haven't looked at the link you're referencing, but if the coolant they used is Dexcool, you need to remove it ASAP.
From my "Gooch" coolant information thread:
Originally Posted by Stewart_H
One thing that importantly needs to be corrected, and a mistake than many misinformed people make, is that not all OAT coolants are like what GM uses. GM typically uses a "Dexcool" formulation, which is specifically not recommended for your diesel engine. Dexcool type coolants were never intended for diesel applications. There are many modern Heavy Duty Extended Life Coolants specifically designed for diesels. Delo ELC, Rotella ELC, International's Fleetrite ELC, CAT ELC, Mobil 1 ELC, and a host of others. They will address diesel cavitatation, provide superior metal corrosion protection, provide better heat transfer, require no testing and maintenance, be free of harmful abrasive silicates, borates, and phosphates, and have an operating life up to 1 million miles (Delo ELC). In fact International, who made your engine, recommends and factory-fills with these Heavy Duty Extended Life Coolants (Fleetrite ELC/Shell Rotella ELC). And in fact almost all heavy duty diesel manufacturers use Heavy Duty ELC's meeting the most strict requirements in the industry...Caterpillar's EC-1. Very little to do with GM's OAT coolant.
No where has Ford said you can not use a heavy duty ELC in your Powerstroke....The only coolants in the Owner's Manual Ford recommends you don't use are Dexcool and Ford's Specialty Orange.
Stewart
Stewart
Old Mar 19, 2017 | 12:26 PM
pirate4x4_camo
Thanks guys.
Looks to my like that is a HOAT.
Old Mar 19, 2017 | 12:54 PM
05MilMachine
The Mopar guys on the forums seem to believe that their 2013 and later coolants are Dexcool. I wouldn't take a chance either way.
Old Mar 19, 2017 | 01:26 PM
pirate4x4_camo
Sure, but then again they are "mopar" guy's so ya know. Ya gotta sorta expect that.
Old Mar 19, 2017 | 01:39 PM
05MilMachine
Truth they probably drank some to see how the flavors compare.
Old Mar 19, 2017 | 04:35 PM
pirate4x4_camo
That is why it is embittered, sure they say so your dog and kids doesn't drink it but it's really the owners.
ryanrk12
6.7L Power Stroke Diesel
Jul 30, 2019 12:33 PM
FSJ-EARL
Oct 29, 2010 08:08 PM
jleal_21
Oct 8, 2009 03:40 PM
Robbgt
Apr 28, 2006 11:43 AM
