Working on bro's truck
#31
Brother what a day.
I got more into the wiring by replacing the busted up turn signal switch.
I've done this a few times with no problems.
I also replaced the voltage regulator on the printed circuit.
When I got it back together I turned the key and nothing, truck was dead. But the turn signals work
Checked to make sure I matched all the wires, Yep.
Checked fuses and had a blown emergency fuse (20 amp). Finding the size to go in there is darn near impossible. Ran around half the day looking.
Still don't have one.
As long as I'm here I'm going to post a few pics and ask you guys if you know what the connectors I'm pointing at are. Also check out the pic of the printed circuit connector. Notice the black wire in the center. Black is ground but this wire is just connected to the common ground nut on the brace right there. Doesn't seem right to me and notice it's been cut and re crimped.
I'm in the walk away and have a drink mode right now. I'm going to research all my questions but I ain't proud and will take all the help I can get.
#33
The ground on the y brace is ultimately where the instrument cluster grounds but it should have done so by an indirect route through one of those existing black wires already there.
The green plug is for the radio. Make sure those aren't metal spades stuck into the hot side of that connector-if they are you will blow the fuse as soon as it grounds out. I think the radio side has the male spades on it. The hot side should be female and yellow black would be key power and blue with red stripe is dimming light circuit for illumination of radio.
Brown plug is for headlight switch activated accessories like clearance lights, trailer light relay etc.
Blue with red stripe goes to ash tray light. The light pushes into a bullet shaped metal piece that clips onto top of ash tray slider frame.
#36
#37
Have a feeling I should check and re ground EVERYTHING.
HIO that's a good idea to print and lam those diagrams. I use them a lot and always end up searching on computer. Would really help to have them right there as you are searching.
Anybody have a lead on those fuses?
IIRC it is a 20A 32V/303
When I searched for them I can only find fuses that are to long for the slot.
#39
#40
I think you're finding AGC fuses which are 1.25 inches long...
What fuse length are you looking for? AGW or AGX???
AGW is 7/8-inch long.... AGX are 1-inch. Here's a guide to glass fuses: http://www.littelfuse.com/~/media/au...rket_glass.pdf
Glass Fuses | Automotive Glass Fuses - Littelfuse
#41
#42
Researching stuff is a personal forte I suppose.... prolly from my college days wandering the stacks at Cal Poly's (SLO) Kennedy library and feeding my persistent intellectual hunger.
#43
#44
#45
