waterpumps
Old Mar 16, 2017 | 08:54 AM
IDIoit's Avatar
IDIoit
waterpumps
curious to know if anyone has ever successfully relocated the front flange on their waterpumps.
the flange that the pulley and the fan clutch bolts to.
I know on other makes of vehicles ive been able to manipulate
this flange out a bit to align the pulley better.
my issue is that my belt rides on the front of the pulley making it obnoxious
it looks like its pressed on, and I tried to use a puller to pull it out, but I felt like it was too much tension and I didn't want to break it.
this was after I pulled the shroud off and realize that I used incorrect bolts,
which lead to the bolts entering the radiator top tank... so I had to replace that as well.
Old Mar 16, 2017 | 08:59 AM
jhl3's Avatar
jhl3
To answer your question, no I haven't.
This is another thought. Have you checked your belt tensioner to make sure it isn't the problem?
Old Mar 16, 2017 | 09:04 AM
IDIoit's Avatar
IDIoit
belt tensioner, water pump, and idler pulley are all bran new.
i would suspect this, but the water pump pulley is directly inbetween the PS pump and the crank pulley.
i did have the powersteering pump pulley off to replace PS pump, but it went back on to the same location at the end of the PSP shaft
jrockdiddy
Oct 25, 2015 12:26 PM
hav24wheel
Aug 25, 2014 12:56 PM
73FOMO
Mar 19, 2014 06:08 PM
sowaxeman
Dec 12, 2010 04:55 PM
Katt
Dec 25, 2000 05:14 PM
