Aod
Old Aug 30, 2003 | 10:59 PM
daerhldgs2's Avatar
daerhldgs2
Aod
I have a rebuilt AOD that I picked up very cheaply , but now I am having shifting problems. Specificly when moving from a start the trans upshifts immediately to drive and doesn't downshift when decellerating. Any ideas what might cause this?
Old Aug 31, 2003 | 04:53 PM
rclarke's Avatar
rclarke
Aod
Check and adjust the throttle pressure linkage. Shift timing is controlled by a balance between the throttle pressure and the governor pressure.
Old Sep 1, 2003 | 09:53 AM
daerhldgs2's Avatar
daerhldgs2
Aod
thanks for the info, I swapped in a new valve body after messing with the tv settings with no success. the trans shifts very well now althought he shifts are a alittle early to my thinking and now I'll start adjusting the TV setting.
