Too much camper???
Old Mar 16, 2017 | 07:11 AM
  #31
senix's Avatar
senix
Exactly! there is enough room for the op to not worry and be able to dry camp easy.
Old Mar 16, 2017 | 08:07 AM
  #32
frt2599's Avatar
frt2599
Originally Posted by Karl4Cat
Yep, no worries there at all! Glad it worked out for you. Be sure to post up pics when she's yours!
Here she is......
Old Mar 16, 2017 | 08:13 AM
  #33
System's Avatar
System
Prolocutor
Originally Posted by frt2599
Here she is......
Looks great!!! Congrats... Oh, and one more point. When you add your airbags and level your truck, your back axle will get lighter and that weight will transfer to the front....
Old Mar 16, 2017 | 08:19 AM
  #34
Desert Don's Avatar
Desert Don
Here she is......
Wow......just wow!!!! Great looking truck!!!!!!!!!! You DO know that color gives you 100 more HP, don't you!!!!!!! You're just short a couple of wheels n tires!! If you haven't guessed by now, I like duallies!!! See mine in my sig.
Congrats on a great looking rig.
  #35
elee3's Avatar
elee3
Very nice!!
Old Mar 16, 2017 | 08:36 AM
  #36
fordmantpw's Avatar
fordmantpw
Here she is......
She's a beaut! Congrats!
Seriously? I hope that's still the case with the '17s!
Old Mar 16, 2017 | 09:45 AM
  #37
frt2599's Avatar
frt2599
Thanks Don, great looking dually you have there.
Originally Posted by elee3
Very nice!!
Thanks Lee
Thanks Tom, I noticed the Birds on the Bat in your sig, you from the STL area?
Thanks Karl, hopefully won't add too much on the pin. Once I get her loaded well do another weigh
Thanks to everyone for all the input and advice. My 2010 Jayco Octane 29ft TT Toy Hauler was totaled out after a hail storm we had a couple weeks ago. Going to a fifth wheel and adding 10 ft. is a little intimidating but I will admit she pulls smoother than my TT did.
Here she is getting towed away by the insurance company. Kind of sad
Old Mar 16, 2017 | 09:51 AM
  #38
System's Avatar
System
Prolocutor
Bob, you'll love the 5th wheel vs. TT. Get her on the highway and it will just stick behind you like and arrow. You won't even notice the extra 10'... until you start camping...
Old Mar 16, 2017 | 09:56 AM
  #39
fordmantpw's Avatar
fordmantpw
I'm actually in central MO (near Jefferson City), but am a big Cards fan!
It's amazing how much better a fifth wheel pulls as opposed to a TT. There is no comparison really!
Definitely sad to see the old one leaving.
Old Mar 16, 2017 | 10:51 AM
  #40
JohnD333's Avatar
JohnD333
You cannot load any more onto the truck - it is at gvwr.
the trailer also added 100# to the front axle. This is what it should do. If the rear sags too much under load, it can actually take load off the front axle.
what you can do is put more into the trailer so long as it does not add to the pin weight. You need to add stuff at the back of the trailer, behind its furthest rear axles. Unfortunately most fresh water tanks, storage areas and empty refrigerators are well forward of those axles.
As Steve said thanks to all the SRW guys for the comments...
OK so had the hitch installed and took her to the scales...
Camper 2016 Fuzion Impact 361 Specifications
Sleeps 8
Slides 3
Length 39 ft
Ext Width8 ft
Ext Height13 ft 1 in
Interior ColorSanta Fe
HitchWeight 3115 lbs
Dry Weight 12820 lbs
Cargo Weight 4180 lbs
Fresh Water Capacity 88 gals
Grey Water Capacity 84 gals
Black Water Capacity 60 gals
Tire SizeST235/80R16E
GeneratorOnan 5.5
Weight from yesterday without the camper
Steering Axle = 4,900
Drive Axle = 3,560
Gross Weight = 8460
Today with camper
Steering Axle 5,000
Drive Axle 6,600
Trailer Axle 9660
Gross Weight 21,250
So Pin Weight.... (camper advertised at 3,115 lb pin weight)
GVWR 11,500 (from door sticker)
GVWR 11,500 minus Gross Weight of truck 8460 = 3,040 left for pin weight
Actual Pin Weight
Drive axle with camper 6,600 minus Drive axle without camper 3,560 = 3,040 actual pin weight (how in the hell did that happen???)
Rear GAWR = 7,000 lb (from sticker)
Actual weight with camper 6,600
GCWR 23,500 (from manual)
Actual with camper 21,250 leaving 2,250 for cargo
Not sure you can load a truck closer to the limits than that...
Air bags go on tomorrow
Old Mar 16, 2017 | 04:19 PM
  #41
senix's Avatar
senix
very nice!
Old Mar 16, 2017 | 07:20 PM
  #42
IronHorsePilot's Avatar
IronHorsePilot
Im going to go out on a limb and ask when you weighed your truck did you have all passengers and "stuff" in the truck as you would normally when you travel? Ive been running numbers like crazy with my truck and what really its me over is the passengers in the vehicle.
Old Mar 17, 2017 | 07:32 AM
  #43
frt2599's Avatar
frt2599
Filled the tank before weighing and just me in the truck. Wife is only other passenger and was not in the truck.
Old Mar 18, 2017 | 01:53 PM
  #44
Jeff Campbell's Avatar
Jeff Campbell
Rodney, I'm surprised there aren't more fifth wheels with the lower pin weight designs. I think duallys are cool, but my truck is my daily driver so I prefer to stick with a SRW. These trucks will tow anything you can hook to them, but the tires have their limits.
To the OP, my fiver pin weighs in at 3000 lbs according to the CAT scales. That puts my drive axle at 6600 lbs. I feel pretty comfortable with that. When I buy new tires, I will get the 295 65r20s that are good for over 4000 lbs each so that I can gain a bit of margin there. I have Firestone Ride Rite air bags that I absolutely love. The rear of my truck doesn't go below level without them, but the overloads are engaged. I like to air the bags up just enough to keep it off of the overloads. Makes for a less bouncy ride.
Great info...
i have similar setup and want to go to 295/65r20 tires. But, concerned about rubbing. Are you planning to level yours? I keep hearing I have to level it to run those tires? If I level I guess I have to do something to the rear to keep from sagging?
Old Mar 18, 2017 | 09:03 PM
  #45
elee3's Avatar
elee3
Originally Posted by Jeff Campbell
Great info...
https://www.ford-trucks.com/forums/1...g-and-psi.html
I'll refer you to the thread above. Look at Painted Horse's posts. He has experience running that size both stock and leveled. Everything that I have heard suggests that it is ok stock. I'm thinking about a 1.5" leveling kit. I would do more, but I don't want to mess with my towing stance too much.
