Air intrusion
I'm chuckling right now.
Next, you went mudding and you "heard your fuel tank fall off." LMAO. That must be some serious freak'n mudd'n.
I'm not sure how you can see bubbles, unless you are running clear hose. Or do you have a temporary clear fuel filter or sight glass?
These don't have spark. Do you mean your glowplugs are functioning?
I'd say it's safe to assume that you don't have an immediate compression issue from a decent session of "mudding," but since you somehow lost a fuel tank in the process, I can't say for sure.
I'd have to ask first if you purged the air out of your injector lines. Since you ran it dry, the IP can empty and air can be lodged in the injector lines. This absorbs the injector pressure so that it can never "pop," thus it'll just keep cranking. You'll need to crack at least four injector lines and wait for the diesel to squirt out as you crank. As they spurt, tighten them down, and you'll work your air out of the lines. Eventually it start to sputter and after four lines are purged, you should be able to crank it and get it started. Rev it a bit so that you can get the other non-cracked injector lines air worked out.
If you crack injector lines and no fuel comes out, you could have a bad IP, or stuck metering valve in the IP, since you said your fuel filter schrader is flowing fuel.
If you want, you can undo the injector line at the injector completely on one line, just to see if any fuel is coming out at all. I put a small plastic pill bottle or baby food jar under it to catch. If after a few decent cranks you don't see any fuel, you might have an IP problem, or clogged injector line, or closed FSS, or lift pump problem, or shut metering IP valve.
ALso, don't crank for too long. Only like 10-20 seconds with the pedal to the floor. Then let the starter rest for a few minutes. It helps A LOT if you have a battery charger set to "crank" because these engines like to have a strong current to get started.
Come to think of it, maybe your problem ain't fuel related, but battery related. How strong are your batteries?
My bets are on that you have air in the fuel lines. Hold the schrader valve and have someone crank the engine. Within a few dozen seconds, it should be flowing without air spurts.
Once the air is purged out of the diesel filter, then crack an injector line. Pull it off the injector completely and put a little jar underneath it. Then crank. If you don't get fuel dribbling out within ten-twenty seconds, your IP isn't getting fuel, or something is stuck.
