Sponsored by: Real Truck
Balancing beads anyone use them?
Old Mar 13, 2017 | 03:07 PM
fishbones182's Avatar
fishbones182
I'm getting a set of Cooper stt pro tires put on the truck this week. Fella at the tire shop asked if I wanted to try running balancing beads. Never heard of them. Tires are 285/70/17 on new rims. What are your thoughts?
Old Mar 13, 2017 | 03:45 PM
hoss66's Avatar
hoss66
They are usually used in larger tires, i would say to have them balanced normally
Old Mar 13, 2017 | 03:57 PM
Sir Kayakalot's Avatar
Sir Kayakalot
As Hoss said, balance beads are usually only used on big tires or tires that require a lot of weight to balance. I'm running that same tire in a 37/13.50/18 and they balanced out fine with regular wheel weights. I don't think balance beads are gonna be necessary for yours.
Old Mar 13, 2017 | 06:02 PM
fordman19762003's Avatar
fordman19762003
I've used them in large truck tires. They seem to work fine, but if you use them make sure you install the special valve stem that has the screen in it to keep the valve core from plugging up.
Old Mar 13, 2017 | 06:23 PM
fishbones182
Thank you for your opinions. I'll have them balanced with regular weights.
Old Mar 13, 2017 | 09:32 PM
SuperDutyScaler's Avatar
SuperDutyScaler
I use them and love them
Old Mar 13, 2017 | 10:32 PM
Ron94150's Avatar
Ron94150
No way I would run beads on a tire that small. You can get a better balance with weights because you can add weight to the inner and outter if needed. A newer tire that size shouldn't use much weight. Beads do work, but don't really start working good until @45-50 mph. You can also hear them at low speeds inside your tire. I balanced my brothers tires on his jeep with air soft bb's from Walmart one time. They worked.
Old Mar 14, 2017 | 05:22 AM
JeepPuller's Avatar
JeepPuller
I run dynabeads in both of my Jeeps and they work great. The 89 has 35s and the 91 has 30s. It is true they don't really start working until you get above 35, but I never notice on the Jeeps.
Old Mar 14, 2017 | 05:26 AM
Shovelheadrob's Avatar
Shovelheadrob
I used dynabeads on my F150 Harley as I didn’t like visible weights, worked fine & as the tires wear you don't need to rebalance.
Old Mar 14, 2017 | 10:32 AM
sunuvabug's Avatar
sunuvabug
They do work on smaller tires too. Not uncommon to have them installed on 14-16" maxi-scooter tires instead of regular weights.
Old Mar 14, 2017 | 11:47 AM
droldsmorland's Avatar
droldsmorland
I believe you can not use the beads if you have TPS monitors in your valve stems. An experienced tire tech should be able to get them properly spin balanced by paying attention to the heavy spots in both the tire and rim. The heavy spots need to be positioned 180* from each other. Then spin balance the assembly while observing any rim or tire run out in the X and Y axis.
Old Mar 14, 2017 | 12:02 PM
Ron94150's Avatar
Ron94150
Many many people run them no problems with tpms. The beads ride along the tire and the sensor of course is on the wheel. The beads are also way to big to effect the sensor.
I totally agree that there is no reason to not spin balance them.
Old Mar 14, 2017 | 04:29 PM
SuperDutyScaler
Dynabeads are sold for motorcycles also, my dad and a bunch of his buddies run them in their harley tires
Old Mar 16, 2017 | 08:11 AM
droldsmorland
I was told by at least two individuals not to run the beads with TPMS. TPS failure was the main theme. Ford did not honor their warranty in both cases because the beads were present. I do not know what the root cause of the sensor failure was...yet.
Old Mar 16, 2017 | 10:00 AM
Rockranch's Avatar
Rockranch
I have been using balancing beads/powder stuff for many years on various vehicles and trailers. Everything from 235/85-17, on a one ton dually, to 225/60-16, on a Honda minivan, as well as various light to heavy 5th wheel and utility trailers. All run great and tires last longer.
