What happens to old posts?
Old Mar 13, 2017 | 02:21 PM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
I had copied some old posts about installing a Chevy Suburban fuel tank in a F-100 a couple of years ago. I finally got to work on my truck and got some flack about cutting a hole in my chassis. So I decided I'd look back on the posts that I read and see if I had done something differently. When I tried to pull up the posts I got a "This is embarrassing but we can't find the post" message.
So what happens to the historical posts on FTE? Are only active members posts kept? I wish I'd have know they wouldn't be available when I kept the link to them. I would have printed them off.
Any discussions would be greatly appreciated.
Old Mar 13, 2017 | 04:48 PM
pweng1's Avatar
pweng1
What i run into many times also is the pics for an old post wont open its just that icon. whats up with that?
Old Mar 13, 2017 | 05:07 PM
bjmayberry2
If the OP moved the picture before (in Photobucket) to a different folder FTE can no longer find the photo by the URL posted originally. Also I'm not sure but if a member isn't on for a while I'm wondering if their account (contributions and pictures) are locked out from other members.
Old Mar 13, 2017 | 06:19 PM
toby tough's Avatar
toby tough
I think they move all the old posts to Antarctica, and then to planet X. Then maybe the aliens abduct them. Sorry, been watching too many you tubes.
Old Mar 13, 2017 | 07:06 PM
56panelford's Avatar
56panelford
old post generally rot at ground level, fall over and continue to rot on the ground unless picked up. But joking aside a lot of very good information was lost when the site decided to do away with everyone's galleries. Pictures disappeared also from posts that used to be in those galleries because the site did away with them plus if the owner of the gallery deleted them from their gallery then you were taken to planet X
Old Mar 14, 2017 | 11:26 AM
petemcl's Avatar
petemcl
If you can post the old link maybe Fomoko1 can look into what happened to it?
Old Mar 14, 2017 | 02:04 PM
bjmayberry2
Tacson’s Chevy Van tank install (55 F 100): https://www.ford-trucks.com/user_gal...d=20494&width=0
Ferguson777’s Chevy tank install (54 F100): https://www.ford-trucks.com/user_gal...d=97344&width=0
bobbytnm’s Chevy tank install (49 F1): https://www.ford-trucks.com/user_gal...d=79496&width=0
Old Mar 14, 2017 | 02:21 PM
schoo's Avatar
schoo
I brought back an old post on chevy gas tank no pic's
Old Mar 14, 2017 | 02:23 PM
bjmayberry2
Was it one of the three I posted?
Old Mar 14, 2017 | 02:25 PM
schoo's Avatar
schoo
no I think another
Old Mar 14, 2017 | 02:29 PM
schoo's Avatar
schoo
https://www.ford-trucks.com/user_gal.../20494.520.390
here's a pic of bobbytnm
it looks like the filler is in between the spring mounts if that is what your after
Old Mar 15, 2017 | 09:26 AM
56panelford
Here's a 73 Chevy Blazer tank which is the same as the suburban tank that I used on my panel. Although the panel was built on a Chev C10 frame the width of the frame is the same as the Ford's. The Chev's frame is heavier that the original Ford frame the rails are a little deeper..
Old Mar 15, 2017 | 11:47 AM
bjmayberry2
Thanks Roy! Exactly what I was looking for. I guess I did mine a little different.
Chevy Fuel tank filler <br/>4" pipe welded into the frame.
I was going to box the frame where I cut through it but was warned I severely weaken the frame and boxing wouldn't make up for the damage. I'm not an engineer so I am at a loss as to what to do.
Old Mar 15, 2017 | 04:31 PM
schoo's Avatar
schoo
here is a pic of my frame I copied dave he has good pic also you can see the white line i only trim the lower rail on the left rail you can just make out the blue marks for filler notch
I trimed the edges straight after adding a rear xmember(from a f250 donor) note the old rear xmember at the spring perch I left a stump to weld a plug weld when I boxed after boxing I put the old xmember at the front of the tank so I have a square around the tank all 1/8"+
Fuel tank is from a Chevy van FI
notch at frame rail to the rear of the spring
Old Mar 15, 2017 | 04:39 PM
schoo's Avatar
schoo
dave (drptopss70)is that spelled correct any way he has much better pic in his builds
Crush tubes for bed bolts ect
bobj49f2
136
Aug 30, 2012 01:22 PM
96sherm
May 7, 2008 10:58 PM
