Need help asap
Old Mar 13, 2017 | 07:14 AM
Navydocsuperduty's Avatar
Navydocsuperduty
Need help asap
Need heelp asap! Released parking brake levered and heard usual sound but no release, brakes still applied... I was messing with SEIC this weekend and may have sent power through the white with violet wire... I am color deficient.... according to Q256 The BCM parking brake input can not source any current. The body builder must supply a high impedence circuit with a 20kohm resistor or larger to prevent faulting the BCM. So is my BCM shot?
Old Mar 13, 2017 | 07:56 AM
Uzumati's Avatar
Uzumati
Not sure which one but I would start with checking all of the fuses in dash and under hood. The diagram doesn't show which one is specifically tied to the bcm but if you did send voltage down an impedance line something should have popped.
Old Mar 13, 2017 | 08:18 AM
Navydocsuperduty
Rgr, looked at any in manual that said BCM, but I'll start going thru them all I guess.
Old Mar 13, 2017 | 09:03 AM
docup!'s Avatar
docup!
Have you looked to see if you are throwing any codes. i dug this up looks like the system may be locking the brakes. Try clearing the codes (if you can)
"Because of a service brake circuit characteristic at engine-start, invoking SEIC may cause the diagnostic error code FFG_BOO to get flagged (recorded in the PCM). To avoid this, simply tap the service brake pedal sometime after engine-start and prior to invoking SEIC. Once the code is set, SEIC may not be available until it is erased."
Old Mar 13, 2017 | 11:23 AM
Navydocsuperduty
Thanks doc, I checked as much as could, had it towed to ford, mech hooked it up and cleared everything. Light still on, he then checked the BCM and it pointed out the light was on, he tried jumping the brake light switch, no luck in turning light off though. I left it with him though, he's on my side, no knowledge of me trying to hook anything up wink wink
Old Mar 13, 2017 | 05:26 PM
Navydocsuperduty
New BCM is what they're telling me..... doh, forehead slap
Old Mar 13, 2017 | 05:30 PM
EpicCowlick's Avatar
EpicCowlick
Not that you can do anything about it now but it would have been interesting to hook up FORScan and run a self test on the BCM. You mentioned there were no DTCs so maybe it wouldn't have shown any failures but with that many failures I'd think it would have shown a problem.
This does bring up an interesting point though. When someone starts getting weird stuff like this, FORScan is an option to pre-test modules before going to a dealer. With the truck under warranty it's not a big deal but as the trucks start aging this is probably something to remember.
Old Mar 13, 2017 | 07:38 PM
T diesel's Avatar
T diesel
I can't help you with the brakes, but the color deficiency, well I'd
look at this.....
https://www.youtube.com/channel/UCRB...AfdLf6oIeyJgiw
Old Mar 13, 2017 | 08:11 PM
Navydocsuperduty
look at this.....
Lol thanks, I can see color, most if em anyways. Just under the dash in the footwell area on an overly bright day, the light beyond the footwell ws over powering to my photo sensitive eyes. Lesson learned that's for sure.
Old Mar 21, 2017 | 07:20 PM
Navydocsuperduty
Well a week in shop and a new bcm & few repaired wires later and I'm back on road. Now I just need to figure out this high idle mod with potentiometer
RIKIL
16
Feb 2, 2023 06:26 PM
TheSterling
Feb 4, 2016 03:08 PM
FordRun
Sep 16, 2015 11:20 PM
Junebug_
13
Aug 19, 2008 05:07 PM
samralh
Jun 24, 2004 10:46 AM
