oil pressure
Old Aug 30, 2003 | 05:29 PM
Phil Yerby's Avatar
Phil Yerby
Question oil pressure
i have a 1989 f150 with a 351 efi engine. my oil guage kept dropping to nothing at idle when the engine is warmed up. i hooked up a mechanical guage where the sending unit is and i get 35 psi at idle and 58 psi at 2800 rpms. is this an acceptible range or do i need a new oil pump?
Old Aug 30, 2003 | 05:40 PM
jwtaylor's Avatar
jwtaylor
oil pressure
The Haynes manual says 40psi at 2000rpm, everyone else says 10 psi for every 1000rpm so I would say you are fine
Old Aug 30, 2003 | 06:24 PM
Phil Yerby's Avatar
Phil Yerby
oil pressure
thanks jw. i think i'll replace the sender.
