My buddy bought a 2011 F150 with a 5.0 a couple a months ago. Has about 160k on it.
He is have issues with the power steering. Apparently the sensors are not reading And ford want $1600 for the part. I guess it is also some mid-year ******* too.
As far as I know, the only fix out there is a new rack from Ford or a used part from a yard. Nobody has come up with a replacement in the aftermarket or a fix for a bad rack.
If you're getting a used rack from a yard make sure it's not a max tow rack. The ratio is different and he probably wants the quicker steer of his original.
Brad you're correct this is a common issue with these trucks. And primarily with the 2011MY. But it's not because of some midyear myth. It's primarily because 2011 was the first year for the EPAS system. Not to mention a whole bunch of other things as well. And just as the dealer told your friend and other have stated here, the entire steering rack will need replaced. Plus he'll need a front end alignment as well once the rack has been replaced. Also if it were my truck (and fwiw I do have a 2011 myself) I would bite the bullet and go with a new O.E. unit rather then a used or aftermarket replacement rack.
so hows it different? I have the 6.2, and it has the hydraulic set up.............
Well, pumps and boxes do leak and fail as well. A good chunk of my friends have older, higher mileage hydraulic systems and everyone of them has had to be repaired. It's also getting harder to find decent prices for the older systems ( I realize you have a newer system).
I don't really know where to look to find failure numbers for the epas. Regardless, if the cubic inches weren't so small and the hydraulic forces so large, I probably would have paid extra for a hydraulic system. Its got to be cheaper to slap in a new box or pump or line than replacing the epas rack, regardless of failure rate.
Reason: forgot basic spelling
Eventually somebody will come out with an aftermarket fix for the EPAS racks that more palatable. All that's wrong is probably a $5 electronic component.
You are correct, but I can replace a pump or box for $500 give or take. The $1600 rack is a considerable difference. I've only ever replaced one box on my '91 F-250 and it has a snow plow hanging off it half the year, I think the box was $200 and change with a shop I use a lot charging 3 hours to swap it out.
I've just read here and on other F-150 forums about a stunning amount of rack failures on a 11-14 trucks
I believe there is some programming involved with a new EPAS set up. Not to difficult of a DIY if you have FORscan.
This is an interesting point. All in all, replacing an EPAS rack should be easier than a hydraulic one since you don't have to deal with any fluid or lines. Thanks to Forscan programming the new rack is pretty easy also. This is the way many auto repairs are going now days. In reality I like the idea of the EPAS system vs. the hydraulic one, but I haven't had to fork over $1k+ for a new one yet.
