Brake Help
Old Mar 3, 2017 | 09:19 PM
PROSTOCK's Avatar
PROSTOCK
Exclamation Brake Help
Hello fellow ford gurus! I am a 15 year old girl using my dads account because I need your help. I am looking to fix/restore an 1965 F-250.
So here is what we have: Front brakes are from a 76 F-250 w/dual piston calipers (8500 and up GVW?) Rear brakes are from a 81 F-250 w/ monstrous drum brakes (12" x 3"). We need a total solution for booster, master cylinder, and proportioning valve that is compatible with this setup. Is it possible that an 81 has the same front brake setup, so an all 81 system will work?
Thank you very much for any input I might receive.
Old Mar 3, 2017 | 10:32 PM
ultraranger's Avatar
ultraranger
1. Dual diaphragm brake booster/brackets from a '68-'77 F250/F350 (turn wrecking yard core booster in for a newly rebuilt dual diaphragm booster part number 54-73112 --(NAPA and O'Reilly parts store number).
2. Disc/drum brake valve from a '73-'79 Dentside F250 with twin piston front calipers.
3. New (not rebuilt) 1-1/16" bore MC for a '78/'79 F250.
https://www.napaonline.com/en/p/NMAM2227
dhglaser
21
Apr 29, 2022 07:07 AM
joe7865
Aug 2, 2018 12:46 PM
Radster
24
Jul 31, 2016 08:47 PM
dansP350
May 17, 2012 07:51 PM
eclectix
Mar 9, 2006 10:02 PM
