How much suck??
Old Mar 2, 2017 | 05:29 PM
muskydawg's Avatar
muskydawg
How much suck??
Evening fellas, my brakes have gone hard, and I'm suspecting it is the vacuum pump. I'll put a vacuum gauge on it. How much suck should I be looking for?
Great quote from the movie Fubar... "you got the suck **** cranked! Turn down the suck, turn up the good!"
Old Mar 2, 2017 | 05:44 PM
Kingkong0192's Avatar
Kingkong0192
I believe it's about 18-20 inches of vacuum.
Check the lines going to and from the vacuum pump
and then check the lines at the manifold where they split off for cracks.
Old Mar 2, 2017 | 06:14 PM
muskydawg's Avatar
muskydawg
If I check the vacuum right at the brake booster should I get the same numbers? Or, do we loose some suction somewhere?
Old Mar 2, 2017 | 06:26 PM
madpogue's Avatar
madpogue
Should be nearly the same at the booster as at the pump; the HVAC should bleed off negligible vacuum. If it's considerably lower at the booster than at the pump, I'd say you have a leak.
Old Mar 2, 2017 | 08:12 PM
97-psd's Avatar
97-psd
If the pump fails your vent controls will suffer as well. If they still work then you may have a brake issue instead of a vac pump issue
Old Mar 2, 2017 | 08:28 PM
muskydawg's Avatar
muskydawg
Thanks men, heading out to the shop to test her out now. It's been so freakin' cold here the vents never move off windshield defrost! -28c here tonight! That converts to, like, really cold in Fahrenheit!
Old Mar 2, 2017 | 09:08 PM
madpogue's Avatar
madpogue
^^^^ I believe that converts to Insane degrees below Friggin'.....
Old Mar 2, 2017 | 09:10 PM
Kingkong0192
Where do you live? In a deep freezer?
Old Mar 2, 2017 | 11:05 PM
muskydawg's Avatar
muskydawg
I live in god's country, Kenora Ontario Canada, just a really cold god right now...
So, the vac pump is porked. She make's zero suck.
The next question is, does a wise man just buy a new pump and carry on. OR... does a wiser, more complicated man change things?? Say, electric vacuum pump, or some other type of super-mod setup?
Also, a little fun fact. The vents seemed to change positions, even with the line right off the vacuum pump? Does this make sense?
Old Mar 3, 2017 | 12:02 AM
madpogue's Avatar
madpogue
No electric pump can run the booster. You'd have to go to hydroboost brakes, then get an e-pump for the HVAC. Doable, but not cheap or easy.
No surprise about the HVAC working; it takes VERY little vacuum compared to the brake booster.
Old Mar 3, 2017 | 12:07 AM
Kingkong0192
You could get rid of the vacuum pump and run a hydro boost setup like found in the super dutys. Unless you tow heavy daily I don't personally think it's worth it.
I bought a replacement A1 cardone vacuum pump from amazon about 8 months ago now from amazon. It's been working awesome. Was about $100 shipped.
As for your vents changing if you unplug the vacuum from them as the pressure changes it could be actuating them.
Old Mar 5, 2017 | 08:26 AM
helifixer's Avatar
helifixer
that is the quote of the day!
mark vanford
Oct 14, 2024 12:31 AM
moroza
Jul 2, 2019 12:59 AM
danlee
Mar 21, 2017 08:25 PM
1poorboy69
Aug 28, 2007 08:01 PM
912504x4
Nov 29, 2006 09:41 PM
