Pedal assembly diagram
Old Mar 1, 2017 | 09:52 PM
F-250 restorer's Avatar
F-250 restorer
Does anyone have a diagram of the assembly? If you have a list of the parts, and a source, that would tremendous. Thx.
Old Mar 1, 2017 | 11:19 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Manual or auto trans? Hang in there, ND will chime in and have locations. Just what is the problem or what part do you need?
Old Mar 2, 2017 | 12:35 AM
F-250 restorer
Thanks for the response. I am converting from an auto trans (1975 f250 with a C6) to a ZF S542. I'm in the process of rebuilding the manual pedal assembly I pulled from the j/y.
Not until I saw your diagram did I realize I was missing some pieces. That I can get from the j/y (clutch return spring and the rod that attaches to the far right end of the bolt that holds the two pedals in place.
I now, with your illustration, can tell what bushings I will need to order. It is very difficult to see on the LMC catalog, or NPD (the worst to understand) what parts to order.
A previous post showed how the owner converted to bearings on the pedal shaft. If that member reads this, could you please give a part #, and possibly a bit of info about the conversion. It looks really good. Thx.
Old Mar 2, 2017 | 06:27 AM
77&79F250's Avatar
77&79F250
Glad I could help, but remember I got these diagrams from folks like ND and mikeo0o0o0.
You know these diagrams have been right here a long time. Ever ck this thread out? https://www.ford-trucks.com/forums/1...then-some.html
Once you figure out the parts needed, post them and their part # here and ND/mikeo0o0o0 will let you know who has them along with their phone#.
Old Mar 2, 2017 | 10:50 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1973/79 F100/350:
There are TWENTY TWO different brake pedals, NINETEEN different power brake boosters, SEVENTEEN different master cylinders, SEVEN different clutch pedals, I kid you not!
Plus, there are SIX different brackets that the brake and/or clutch pedals suspend from, THREE are specific to A/T, THREE are specific to M/T
Whatever booster/master cylinder is used must match the pedals. The pedals have stamped ID numbers used to ID them.
Old Mar 2, 2017 | 11:13 AM
F-250 restorer
1973/79 F100/350:
Hello, ND. I will find the pedal number you mention so I can be assured of getting the proper bushings for the pivot rod. I assume those bushings are the same for all manuals, all automatics? Does anyone know a source for the clutch return spring? and the bushings?
My installation, however, does not depend on finding the matching numbers to coordinate booster with pedal, since I use a hydroboost booster, and will be modifying the clutch pedal to accept/operate a hydro clutch master that came on a 1991 ford truck.
Wabanubu
1997 - 2003 F150
Mar 30, 2019 11:10 AM
grinnergetter
Aug 2, 2015 09:06 PM
SIXTFOR
May 7, 2014 11:44 AM
MossyHeart
Mar 27, 2007 08:32 PM
