1966 F250 Camper Special - One Owner - New to me
#123
#124
Making progess
Began putting the accesories on the engine. I had the flywheel machined and a new ring gear installed at the machine shop while the engine was being rebuilt. Installed a new clutch and pressure plate and used the transmission to fit it properly just to be sure it would go back to together easily when laying under the truck. The alignment tool that came with the clutch kit did not fit in my bearing. Also installed the bell housing and the starter then set the engine in place and installed studs to be used when mounting the exhaust manifolds. Here are few pics.
#125
Made some progress over the last few days. All accessories installed on the engine, exhaust manifolds installed (still need some long studs to connect the exhaust on drivers side). Today I rented a transmission jack and installed the NP435 by myself. I don't recommend this but sometimes you have to press on. Glad to have it this far along. Need a few misc items and I will be firing it up soon.
#126
#127
#130
#131
#135
I bought the carpet from Custom Automotive Carpet. Here is the link https://www.accmats.com/ The carpet does contour nicely to the floor. I highly recommend them.
