Trailer pulling
Old Feb 27, 2017 | 11:27 PM
2BSDowner's Avatar
2BSDowner
Trailer pulling
I am new to pulling trailers at least anything that I would need a SD for. So excuse my ignorance…
In towing there are 3 basic problems, correct?
Over loading the trailer
Having too much tongue weight
Having too little tongue weight
Have I missed any?
I know they are all bad but which is the worst case?
I got to thinking about this because of the recent Weigh Safe Hitch posts. How does the WSH help? Don’t get me wrong I think the WSH is a very intriguing product. As far as I can see in order to effectively use the WSH I have to know the weight of the trailer as loaded. Then I can confirm the tongue weight percentage.
Old Feb 27, 2017 | 11:44 PM
theboom's Avatar
theboom
Have I missed any?
The weigh safe hitch just shows you how much weight is on the tongue of the trailer. Then yes if you know the weight of the trailer, its simple math and reading what the hitch says to get the right percentage. Really cool hitch.
Yes you have got it down pretty much. In addition to your 3 listed, I would add your payload rating, gcwr, and max towing. Make sure you don't exceed any of them. Some people may say different but if I had to pick the worse one it would be not enough tongue weight. Can cause MAJOR stability issues.
I see in your sig that you are getting a f450. Your not going to have to worry THAT much about it. You still need to pay attention to it and make sure you don't go over it but that's going to be hard with a f450 unless your really try. Its just such a beast of a truck. First diesel, first 4x4, first dually? You will fall IN LOVE with it. You picked a hell of a truck to be your first everything. Nice decision
Old Feb 28, 2017 | 07:22 AM
K A M's Avatar
K A M
All three are important
Old Feb 28, 2017 | 08:30 AM
Desert Don's Avatar
Desert Don
Have too little tongue weight
Have I missed any?
^^^^^^ THIS is the worst case scenario!!!!! All others that you listed will not affect handling like too little tongue weight!!!!
Too little tongue weight WILL induce sway just by itself, with no other input!!!!
I.E. it will start swaying all by itself, even if you have no wind, perfectly smooth, perfetly straight road, no passing semi's!!!!
Old Feb 28, 2017 | 08:44 AM
crewzer's Avatar
crewzer
Lightbulb
I strongly recommend a thorough read of Ford's 2017 RV and Trailer Towing Guide.
HTH,
Jim / crewzer
Old Feb 28, 2017 | 12:08 PM
bikerman5345's Avatar
bikerman5345
Also, just because your getting a big dually dont let your guard down while loading and driving. I was driving back from illinois this past weekend and saw a dually on the side of the interstate on its side with a smaller travel trailer behind it destroyed. it was maybe a 20ft trailer. Complacency is the worst mindset.
DirtyLarry
Apr 12, 2015 06:15 PM
RickBetterley
6.7L Power Stroke Diesel
Apr 26, 2012 09:32 AM
Mama Paz
2004 - 2008 F150
Jun 6, 2010 09:33 AM
Chris89lx
All Things Towing
18
Mar 27, 2009 04:12 PM
spongebobshane
All Things Towing
Jul 13, 2004 12:29 AM
