So then in theory, if I want an aftermarket wheel, up to 1997 works?
Truck carries an Alaskan camper too so it's heavy.
What about offset? What is stock?
I believe stock offset is zero. Though most wheel options come with negative offset, increasing clearance.
Yep my 93 with 15" rims have a zero offset and I bought after market 17's with a positive 25mm offset. I had to use 25mm / 1/2 inch spacers to keep from rubbing
I don't know what you are talking about. I saw about 40 different models when I looked on Tire Rack last night. Plus all of the OE options available for the past 40 years.
