Rough idle after hard to start hot/cold problem fixed.
I have an 01 f350 7.3 with about 330000 miles on it with a rough idle only on acceleration. The issue began after hard to start cold/hot problem was fixed. It has a vibration to it on acceleration so at first I thought it was a tire or suspension problem but the vibration stops when you let off of the gas. Things I’ve done so far to it is replaced gpr, glow plugs, valve cover gaskets, icp sensor, cps (grey), ebp sensor and tube which was plugged up, new batteries and new positive cables, and had a low turbo boost pressure code removed which did not come back. I’ve been told by the dealership that it has passed the injector buzz test and they can’t find anything wrong with it. It’s now showing on contribution test injector 3 & 8 codes. Any suggestions will help thanks : >
p0269
p0284
i think it may be a fuel pressure issue? That’s my next step I guess
mrjimbov
40
03-31-2021 11:35 AM
naga77777
30
01-27-2016 05:32 PM
gscoggin3
09-12-2015 03:25 PM
Shepherd2
02-26-2014 05:03 AM
surfnturf
16
11-25-2010 04:56 AM
