Are these the same lifters?
Old Aug 29, 2003 | 04:59 PM
Lurk's Avatar
Lurk
Question Are these the same lifters?
Are the hydraulic lifters out of a 302 v8 and 300 straight 6 interchangeable? Both engines are from around early 80s or late 70s, something like that anyway. I have a 302 doing nothing but collecting rust and want to use the lifters out of it in the straight 6 already in a pickup if it's possible.
I can't find anything on the net that tells me. I also am no good at searching for these types of things.
Old Aug 29, 2003 | 10:58 PM
Franklin2's Avatar
Franklin2
Go to autozone.com or partsamerica.com and plug in your vehicle. Pick a six and write down the lifter part numbers. Then pick a v8 and do the same. See if the part numbers are the same. You can also go to napaonline.com and check.
