Hope those Chevy boy's don't forget to drain their hood!
I thought I read somewhere that the new L5P Duramax use the hood scoop for passive cooling. To keep that new beast of an engine running cooler. But watching a video of "The Fast Lane Now" I realised that the hood scoop is actually an active water separator and works more as a RAM air intake. It appears that the water separator will just leak down out of the drain plug, but is kinda funny as they may seriously have to think about draining that thing if it ever gets clogged.
Whats everyones thought on longevity of this design? Seems like a car wash or well timed water splash would almost dump water straight into the intake filter.
Link to Chevy's press release relating to the hood scope from Jun 2016.
All-new Intake System Feeds Duramax Diesel on 2017 Silverado HD
Yeah, I am a little leery of this system. I knew it was a ram air setup and read that it had a water seperator, but didn't know it had to be manually drained.
I wonder how much testing they did on that. I foresee issues honestly.
The other thing I would hate if I were a GM guy, would be the hard headedness of GM to STILL be putting that DEF tank where they are. It is a serious eye sore and it's in danger of getting damaged every time the truck is driven off pavement.
I'm glad Ford is doing the things they are doing, I know Ford does things that annoy us at times, but they listen to us more than GM does.
on
The under-hood photos are interesting. The air coming in from the hood scoop has to make a hard left turn over to the passenger side of the truck and down into the air box. So at least two 90-degree turns. The bulk of the air is still drawn from inside the fender. GM claims they can get cooler air from the top of the hood. There is a piece of reflective tape positioned directly under the air intake, but there is a lot of engine heat radiating upwards and heating the air passageway. GM truck's don't have as effective of a CAC as the Ford's water-cooled setup in hot conditions, so they need the intake air to be as cool as possible. But mostly, I'd say this is a gimmick to advertise the new engine. I'm sure it has been thoroughly tested.
Aren't the engines rated on a dyno in a control booth? All the manufacturers ratings are optimal engine-on-stand numbers and don't account for in vehicle driveline losses. Any benefit that the ram air actually provides couldn't have shown up in the 445 HP number.
...The bulk of the air is still drawn from inside the fender. GM claims they can get cooler air from the top of the hood. There is a piece of reflective tape positioned directly under the air intake, but there is a lot of engine heat radiating upwards and heating the air passageway.....
Troverman, you did mention a very interesting point, with all those twist and turns in the hoods air channel, I'm surprised to see Chevy claiming this as helping to provide COLD air intake. They have a lot of heat shield/insulation material between the engine and hood, but what about the internals, between intake passes and the hot sun baking down the all that steel?
