All coils created eaqual?
My first impression, they are so close to a 1/2 ton or a 1 ton, just cut out the middle man and offer a 1/2 ton or a 1 ton. Would maybe be cheaper production cost and life in general would just be simpler.
But this was also furring the war in 1942, not sure how much if any influence that could have been.
Other trucks in the time period, "my 1949 dodge 3/4 ton" The only difference between the 1/2 and 3/4
Wheelbase is 10" longer
Brake drums/shoes are larger 11" instead of 10"
The bigger 3/4 ton they went from 5 on 4.5" bolt pattern wheels to 5 on 5"
The 1/2 ton have 16" 4.5" wide wheels and the 3/4 ton have 15" 5" wide wheels.
More rear leaf springs, over loads option.
Sure I might have missed something, but not much.
There is just a lot of little changes that do not add up to any real value.
Why I think that maybe Ford was trying to cut out the 3/4 ton, but it did not go away and they brought it back in 1948.
Pretty sad because it is in real nice shape. Grandpa bought the F5 in the 60's and he used the big box on it for a storage shed.
Grandpa told me it was leaking antifreeze and I thought it was a cracked block, my uncle says that nobody has ever really looked at it and thinks it may be a freeze plug.
Either way, the odometer only has 17k miles showing on it, all the wear indicators like the rubber on the pedals looks like it is accurate.
But there is no real market for these big trucks.
The maroon jailbar picture above, My uncle said he had a chance to buy it from a local car lot for $1k.
Said it ran but needed a water pump, he passed on it.
I tried to turn the engine over today, it is locked up tight. There is 2 lower pulleys on it, I was able to get a 24" pipe wrench inbetween them and pull pretty good..
Did not want to budge. May have to pull the heads off of it next.
All I have done so far is put ATF in the cylinders. While doing so, I see the coil is missing.
Before going down to napa and buying a new coil, Can I use any 6 volt coil to just try and get it running?
I have available a 1952 ford flathead v8 and 2 dodge flathead 6 that could borrow a coil from. All 6 volt positive ground.
Seems to me that they should work fine, assuming they are good.
Trying to research and read, the internet starts talking about resistors and condensers, And is where I get lost. I thought I would ask you fine gentlemen what you think.
Was trying to hold off spending any money until get it unstuck and turning over.
Been to busy this week, but plan to completely fill the cylinders with atf, let it sit for a bit more.
So far I have about a 1/2 quart in all 8 cylinders.
This means that in October I poured in about a 1/4 quart between all cylinders, then around December I did the same.
Now I am just going to pour it in til it runs out the plug holes and let it soak.
